101-103_ALT_0
Wired Home 3106AD0E RG-6/U Solid Copper Tinned Braid 250ft
Brand:| Model: 3106AD0E
A solid copper center conductor, within Wired Home's RG-6/U cable, is the perfect signal path for high performance signals transmitted and received by multi-LNB satellite and digital cable receivers. Additionally, Wired Home's RG-6/U can be used to make custom high performance A/V patch cables.
  • 18 AWG solid copper center conductor
  • 95% coverage tinned copper braid
  • 125% coverage Mylar foil
  • UL, C-UL listed and CMG rated
  • Sequential foot markers indicate cable remaining on the spool
101-103
Weight: 11 lbs.
IN STOCK
List Price$106.99
You Save45%
$58.05
Buy 4-up$53.36
Part # 101-103
The added capacity of HDTV channels available from digital cable and satellite makes it necessary to reconsider the type of coaxial cable used for installations. Poor quality cable causes a higher DC voltage drop along the cable length. This limits channel bandwidth resulting in a less than predictable performance potentially creating service calls. A solid copper center conductor, within Wired Home's RG-6/U cable, is the perfect signal path for high performance signals transmitted and received by satellite and cable receivers. The tinned copper braid provides 95% coverage and is also ideally suited for surveillance cameras that transmit data over the shield. Aluminized Mylar foil is bonded to the dielectric (125% coverage) to provide 100% shield protection from EM and RF interference. UL and C-UL listed; CMG rated for use within walls. Additionally, Wired Home's RG-6/U can be used to make high performance custom length composite, component, stereo audio, and subwoofer patch cables when terminated with Wired Home's RCAX-AU audiophile-grade RCA connectors.
Specifications: • Center conductor: 1.02 mm dia. solid copper • Dielectric: 4.57 mm dia. foamed PE • Shield: 125% coverage aluminized Mylar foil and 95% coverage 168 x 0.12 mm dia. tinned copper braid • Nominal impedance: 75 ohms • Velocity of propagation: 82% • Capacitance: 53.1 pF/meter • Nominal attenuation: 21.6 dB/100 meters @ 1 GHz • Overall diameter: 6.86 mm • Cable dispensed from a plastic spool.
  • Cable Rating CMR Rated,UL Approved
  • Coaxial Cable TypeRG-6/U
  • Jacket ColorBlack
  • Length250 ft.
  • BrandWired Home
  • Model3106AD0E
  • Part Number101-103
  • UPC844632071096
  • Product CategoryRG-6 / RG-59 / RG-58 Coaxial Cable
  • Weight11 lbs.
View similar products to the Wired Home 3106AD0E RG-6/U Solid Copper Tinned Braid 250ft
in the RG-6 / RG-59 / RG-58 Coaxial Cable product category.
Do Use You Normal Compression ends or the Quad?
Asked by: haru15
This cable would use typical RG-6 connectors, it is not a quad shield cable .
Answered by: RussR
Date published: 2012-06-27
Customer projects that include: Wired Home 3106AD0E RG-6/U Solid Copper Tinned Braid 250ft
