Wired Home 205E6Y Cat 5e Shielded CMR Solid 350 MHz Blue 500 ft.
Brand:|Model: 205E6Y|Part # 101-029
Wired Home's shielded Cat 5e bulk cable features a 125% overlapped Mylar wrap over four twisted pair conductors, for virtual immunity from electro-magnetic and radio frequency interference.
List Price$174.99
You Save53%
$81.86
Buy 4+$79.41
Part # 101-029
  • High noise-rejection design eliminates interference
  • 125% overall Mylar wrap provides maximum signal protection
  • Shielded twisted-pair cable construction with a single drain wire for easy connections
  • 350 MHz bandwidth far exceeds 100 MHz bandwidth of standard Cat 5e
  • Sequential foot markers indicate cable remaining in the box
Wired Home's shielded category 5e cable overcomes electrically noisy environments, common in industrial settings, to provide a clear and undistorted signal path for computer, telephone, and surveillance networks. The cable's aluminized Mylar shield employs an easily-connected single tinned-copper drain wire to route noise to ground.
A 350 MHz cable bandwidth allows for advanced applications, including high-speed Ethernet networks and A/V signal transmission using baluns (including HDTV quality signals). Also meets or exceeds the standards set forth by EIA/TIA 568B.2 for performance and UL and NEC riser rating requirements for vertical flame testing. The cable's Spool-in-Box payout system saves installers time and money by virtually eliminating performance-robbing cable kinks (common with other manufacturers' bulk Cat 5e cable) during installation.
Specifications: • Individual conductors: 24 AWG (0.52 mm dia.) solid copper • Drain wire: 0.4 mm dia. tinned-copper • Nominal impedance: 100 ohms (±15 ohms) • DCR: 8.9 ohms/100 meters • Capacitance: 4800 pF/100 meters • Attenuation @ 350 MHz: 44.9 dB • Overall cable diameter: 6.10 mm (± 0.10 mm).
  • Cable Rating CMR Rated
  • Special FeaturesShielded
  • Wire Gauge24 AWG
  • Jacket ColorBlue
  • Length500 ft.
  • BrandWired Home
  • Model205E6Y
  • Part Number101-029
  • UPC844632071584
  • Product CategoryCat 5 / Cat 6 Network Cable
    (2 Reviews)
  • Weight15.65 lbs.
View similar products to the Wired Home 205E6Y Cat 5e Shielded CMR Solid 350 MHz Blue 500 ft.
in the Cat 5 / Cat 6 Network Cable product category.
Wired Home 205E6Y Cat 5e Shielded CMR Solid 350 MHz Blue 500 ft. is rated 5.0 out of 5 by 2.
Rated 5 out of 5 by from Exactly what I neededRock solid. Shielding was great, Sheath was solid but easy to strip. Made up several dozen connections so far and not one failure
Date published: 2015-03-16
Rated 5 out of 5 by from A Great Choice for InstallationI bought 1500' (three boxes) for an installation that demands STP such as VGA and USB adapters over CAT5 as well as AES50 connections for Klark-Teknik digital audio snakes. I am very happy with the quality of the insulation and the overall construction. It is easy to strip and terminate. The shielding isn't the absolute highest quality, however; it is just a foil shield and drain wire as opposed to a full braid shield. But the price is right. For permanent installation, it's a great choice!
Date published: 2013-11-17
  • 2016-02-14T07:20CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_101-029, PRD, sort_mostRecent
