101-037_ALT_0
Wired Home 1066Y Cat 6 CMR Solid Cond 500 MHz Blue 500 ft.
Brand:| Model: 1066Y
Wired Home Cat 6 cable was designed, manufactured, and verified to meet and exceed published standards for EIA/TIA 568B.2. Features include a superior 550 MHz bandwidth compared to standard 250 MHz Cat 6 cable, and a central spline that separates the individual pairs, which results in decreased crosstalk.
  • Rated to 550 MHz—exceeding the performance of standard 250 MHz Cat 6
  • Central spline decreases noise and crosstalk
  • Verified EIA/TIA 568B.2 and 10BASE-T, 100BASE-TX, 1000BASE-T, and 10GBASE-T compliant
  • Sequential marks every two feet, shows cable remaining at-a-glance
  • Spool-in-Box payout system virtually eliminates cable kinks
101-037
Weight: 17.35 lbs.
IN STOCK
List Price$181.99
Regular Price$88.21
You Save17%
Sale Price
$72.98
Part # 101-037
Category 6 cable provides a high-speed pathway for gigabit Ethernet performance. Perfectly suited for applications including computer network, telephone, surveillance, video distribution, audio, and infrared system control. UL and NEC requirements have been met for vertical flame tests, making this cable riser rated for in-wall and in-ceiling installations.
Packaging was designed around the Spool-in-Box payout system. This saves installers time (and money) by virtually eliminating performance robbing cable kinks (common with other manufacturers' bulk Cat 6 cable) during installation. Alternatively, the box's internal spool may be removed to "rack-up" on a traditional cable caddy.
Specifications: • Individual conductors: 23 AWG (0.57 mm dia.) solid copper • Nominal impedance: 100 ohms (±15 ohms) • DCR: 6.9 ohms/100 meters • Capacitance: 5000 pF/100 meters • Attenuation @ 550 MHz: 52.8 dB • Overall cable diameter: 6.10 mm (± 0.10 mm).
  • Cable Rating CMR Rated
  • Wire Gauge23 AWG
  • Jacket ColorBlue
  • Length500 ft.
  • BrandWired Home
  • Model1066Y
  • Part Number101-037
  • UPC844632071607
  • Product CategoryCat 5 / Cat 6 Network Cable
    (2 Reviews)
  • Weight17.35 lbs.
View similar products to the Wired Home 1066Y Cat 6 CMR Solid Cond 500 MHz Blue 500 ft.
in the Cat 5 / Cat 6 Network Cable product category.
Wired Home 1066Y Cat 6 CMR Solid Cond 500 MHz Blue 500 ft. is rated 5.0 out of 5 by 2.
Rated 5 out of 5 by from No Problems what-so-everI pulled (4) cat-6 drops through my condo and they all terminated on the first try using the self-terminating jacks from parts-express. I get the full gigabit speeds and are working great!
Date published: 2014-09-09
Rated 5 out of 5 by from good stuffworks great easy feed box came on time and was installed with out fuss
Date published: 2013-04-05
Customer projects that include: Wired Home 1066Y Cat 6 CMR Solid Cond 500 MHz Blue 500 ft.
