Wired Home 1066U Cat 6 CMR Solid Cond 500 MHz Blue 1000 ft.
Brand:|Model: 1066U|Part # 101-039
Wired Home Cat 6 cable was designed, manufactured, and verified to meet and exceed published standards for EIA/TIA 568B.2. Features include a superior 550 MHz bandwidth compared to standard 250 MHz Cat 6 cable, and a central spline that separates the individual pairs, which results in decreased crosstalk.
List Price$358.99
You Save59%
$147.18
Buy 4+$142.78
Part # 101-039
  • Rated to 550 MHz—exceeding the performance of standard 250 MHz Cat 6
  • Central spline decreases noise and crosstalk
  • Verified EIA/TIA 568B.2 and 10BASE-T, 100BASE-TX, 1000BASE-T, and 10GBASE-T compliant
  • Sequential marks every two feet, shows cable remaining at-a-glance
  • Spool-in-Box payout system virtually eliminates cable kinks
Category 6 cable provides a high-speed pathway for gigabit Ethernet performance. Perfectly suited for applications including computer network, telephone, surveillance, video distribution, audio, and infrared system control. UL and NEC requirements have been met for vertical flame tests, making this cable riser rated for in-wall and in-ceiling installations.
Packaging was designed around the Spool-in-Box payout system. This saves installers time (and money) by virtually eliminating performance robbing cable kinks (common with other manufacturers' bulk Cat 6 cable) during installation. Alternatively, the box's internal spool may be removed to "rack-up" on a traditional cable caddy.
Specifications: • Individual conductors: 23 AWG (0.57 mm dia.) solid copper • Nominal impedance: 100 ohms (±15 ohms) • DCR: 6.9 ohms/100 meters • Capacitance: 5000 pF/100 meters • Attenuation @ 550 MHz: 52.8 dB • Overall cable diameter: 6.10 mm (± 0.10 mm).
  • Cable Rating CMR Rated
  • Wire Gauge23 AWG
  • Jacket ColorBlue
  • Length1,000 ft.
  • BrandWired Home
  • Model1066U
  • Part Number101-039
  • UPC844632071614
  • Product CategoryCat 5 / Cat 6 Network Cable
    (4 Reviews)
  • Weight31.95 lbs.
View similar products to the Wired Home 1066U Cat 6 CMR Solid Cond 500 MHz Blue 1000 ft.
in the Cat 5 / Cat 6 Network Cable product category.
Wired Home 1066U Cat 6 CMR Solid Cond 500 MHz Blue 1000 ft. is rated 5.0 out of 5 by 4.
Rated 5 out of 5 by from The best network cable I have usedI am extremely happy with this cable. I did a lot of research and was amazed at the value you get with this. A lot of other companies claimed to sell Cat 6 cable but they were 24ga. In my opinion, this cable meets and exceeds the cat 6 requirements. I have used around 750ft so far and every run has worked flawlessly. The cable itself is thicker and stiffer than some other brands. This can make it easier or harder to run the cable depending on the situation. Compared to other brands, the color coding is easy to see and rich in color. If you install cable, you know how hard it is to see the color strips on the white wires. When you punch down the cable into a keystone it also locks into place securely. The wire is not limp which makes it easier to pierce the insulation.
Date published: 2014-05-21
Rated 5 out of 5 by from Solid, DependableI used this product for a basement remodel project. It was easy to pull, and the jacket is thick and durable. I have it all connected to wall jacks and a patch panel in which I had no problem punching down the individual pairs. All cables work and would highly recommend!!!
Date published: 2013-07-18
Rated 5 out of 5 by from Good cableThis cable is great. Much higher quality than the local electrical supply houses have and a better price too. I have gone through 4-5 boxes so far and I am about to order a bunch more.The only possible downside of this cable is that it is somewhat stiff and heavy. A box of this cable is significantly heavier than a box of most other cable. I like the stiffness though it is more resistant to kinking when pulling it.
Date published: 2013-02-20
Rated 5 out of 5 by from Great, with one exception.The payout box reel tends to break in shipping making the payout tragically difficult. When the box is undamaged it works very well. Terminating is good with the EZ connectors once you get the hang of it. So far no problems with signal.
Date published: 2011-04-22
  • 2016-02-10T07:07CST
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_101-039, PRD, sort_mostRecent
What is your cat6 wire made out of?
Asked by: MikeinNewJersey12
This cable uses 23 gauge solid copper conductors.
Date published: 2014-06-23
Will this cable work if run it along with power thru my new home, or will I need a shielded cable?
Asked by: gumby46
Never run a low voltage cable through the same holes as power cable. You should always leave 10 to 12 inches between power cables and low voltage cables. If crossing a power cable, make sure to cross at a 90 degree angle. Failure to adhere to building codes will result in project delays and cost more money.
Answered by: PE Tom
Date published: 2013-07-01
  • 2016-02-10T07:38CST
  • loc_en_US, sid_101-039, PRD, sort_recentQuestionsFirst
