Wired Home 105E9Y Cat 5e CMR Solid Cond 350 MHz White 500 ft.
Brand:|Model: 105E9Y|Part # 101-021
Wired Home's bulk Cat 5e cable features 350 MHz bandwidth for high-speed Gigabit Ethernet networks while meeting or exceeding the standards set forth by EIA/TIA 568B.2 for performance. Complies with UL and NEC riser rating requirements for vertical flame testing.
List Price$123.99
You Save52%
$59.80
Buy 4+$58.01
Part # 101-021
  • 350 MHz rating far exceeds the performance of standard 100 MHz Cat 5e
  • Unshielded quad twisted pair construction
  • Ideal for computer network, voice, video, sound
  • Spool-in-Box payout system virtually eliminates cable kinks, works with cable caddies
  • Sequential marks every two feet show remaining cable at-a-glance
  • CMR rated, UL, and C-UL listed; verified EIA/TIA 568B.2 compliant
Category 5e cable has become the standard cable type used in commercial and residential structured wire systems for telephony, computer networking, and surveillance…and more! Wired Home's bulk Cat 5e features 350 MHz bandwidth for advanced applications, including high-speed Gigabit Ethernet (1000BASE-T) networks and A/V signal transmission using baluns. Meets or exceeds the standards set forth by EIA/TIA 568B.2 for performance, as well as UL and NEC riser rating requirements for vertical flame testing.
Wired Home Cat 5e cable's packaging was designed around the Spool-in-Box payout system. This saves installers time and money by virtually eliminating performance-robbing cable kinks (common with other manufacturers' bulk Cat 5e cable) during installation. Alternatively, the internal spool may be removed to "rack-up" on a traditional cable caddy.
Specifications: • Individual conductors: 24 AWG (0.50 mm) • Nominal impedance: 100 ohms (±15 ohms) • DCR: 9 ohms/100 meters • Capacitance: 5000 pF/100 meters • Attenuation @ 350 MHz: 44.9 dB • Overall cable diameter: 5.10 mm (± 0.10 mm).
  • Cable Rating CMR Rated
  • Wire Gauge24 AWG
  • Jacket ColorWhite
  • Length500 ft.
  • BrandWired Home
  • Model105E9Y
  • Part Number101-021
  • UPC844632071560
  • Product CategoryCat 5 / Cat 6 Network Cable
    (3 Reviews)
  • Weight13.95 lbs.
View similar products to the Wired Home 105E9Y Cat 5e CMR Solid Cond 350 MHz White 500 ft.
in the Cat 5 / Cat 6 Network Cable product category.
Wired Home 105E9Y Cat 5e CMR Solid Cond 350 MHz White 500 ft. is rated 5.0 out of 5 by 3.
Rated 5 out of 5 by from Great cable, easy installBought this for a video conferencing install in our Education Center at work. Was very easy to work with, terminate, and we have had no issues.
Date published: 2015-04-29
Rated 5 out of 5 by from best speaker wirei build and rebuild speakers and this stuff beats out the overpriced audiofile stuff and i don't have to take a second on my house to afford it. the solid core is better than stranded.
Date published: 2012-09-16
Rated 5 out of 5 by from Excellent quality and wire amount for the moneyPrimarily I purchased this spool of cable to install security cameras in my residence. Cable quality is great. I ran this wire to the security cameras where needed without issue. It should be a great quality cable for your Ethernet network needs as well.
Date published: 2012-01-27
  • 2016-02-13T07:05CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_101-021, PRD, sort_mostRecent
Is this solid copper?
Asked by: alamez
Yes this is solid copper.
Date published: 2013-04-29
  • 2016-02-13T07:58CST
  • loc_en_US, sid_101-021, PRD, sort_recentQuestionsFirst
