Wired Home 105E8Y Cat 5e CMR Solid Cond 350 MHz Gray 500 ft.
Brand:|Model: 105E8Y|Part # 101-013
Wired Home's bulk Cat 5e cable features 350 MHz bandwidth for high-speed Gigabit Ethernet networks while meeting or exceeding the standards set forth by EIA/TIA 568B.2 for performance. Complies with UL and NEC riser rating requirements for vertical flame testing.
List Price$123.99
You Save51%
$60.42
Buy 4+$58.61
Part # 101-013
  • 350 MHz rating far exceeds the performance of standard 100 MHz Cat 5e
  • Unshielded quad twisted pair construction
  • Ideal for computer network, voice, video, sound
  • Spool-in-Box payout system virtually eliminates cable kinks, works with cable caddies
  • Sequential marks every two feet show remaining cable at-a-glance
  • CMR rated, UL, and C-UL listed; verified EIA/TIA 568B.2 compliant
Category 5e cable has become the standard cable type used in commercial and residential structured wire systems for telephony, computer networking, and surveillance…and more! Wired Home's bulk Cat 5e features 350 MHz bandwidth for advanced applications, including high-speed Gigabit Ethernet (1000BASE-T) networks and A/V signal transmission using baluns. Meets or exceeds the standards set forth by EIA/TIA 568B.2 for performance, as well as UL and NEC riser rating requirements for vertical flame testing.
Wired Home Cat 5e cable's packaging was designed around the Spool-in-Box payout system. This saves installers time and money by virtually eliminating performance-robbing cable kinks (common with other manufacturers' bulk Cat 5e cable) during installation. Alternatively, the internal spool may be removed to "rack-up" on a traditional cable caddy.
Specifications: • Individual conductors: 24 AWG (0.50 mm) • Nominal impedance: 100 ohms (±15 ohms) • DCR: 9 ohms/100 meters • Capacitance: 5000 pF/100 meters • Attenuation @ 350 MHz: 44.9 dB • Overall cable diameter: 5.10 mm (± 0.10 mm).
  • Cable Rating CMR Rated
  • Wire Gauge24 AWG
  • Jacket ColorGray
  • Length500 ft.
  • BrandWired Home
  • Model105E8Y
  • Part Number101-013
  • UPC844632071546
  • Product CategoryCat 5 / Cat 6 Network Cable
    (1 Reviews)
  • Weight13.8 lbs.
View similar products to the Wired Home 105E8Y Cat 5e CMR Solid Cond 350 MHz Gray 500 ft.
in the Cat 5 / Cat 6 Network Cable product category.
Wired Home 105E8Y Cat 5e CMR Solid Cond 350 MHz Gray 500 ft. is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Best Quality and Easy to UseI've been using this cable for years now. It is by far, hands down the best for in-wall runs. The jacket is sturdy and firm and doesn't crimp up easily in your pulls. The twisted pair is thick and colorful so it makes crimping and punching down a breeze. I've used a varied number of brands in jobs where vendors ordered solid cable for their sites and most had problems. Flimsy jacketing, faded or off-color coded twisted wire... all the things that eat time and rob quality. I just wish they made this cabling in more colors than gray.
Date published: 2012-12-23
  • 2016-02-06T07:25CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_101-013, PRD, sort_mostRecent
This question is in regards to your product, Wired Home 105E8Y. Is this cable solid copper or is it copper clad aluminum (CCA) cabling? I'm sorry if I missed it in the description. Any assistance would be greatly appreciated.
Asked by: gfith326
These are solid copper conductors.
Date published: 2015-06-24
  • 2016-02-06T08:46CST
  • loc_en_US, sid_101-013, PRD, sort_recentQuestionsFirst
