Wired Home 105E6Y Cat 5e CMR Solid Cond 350 MHz Blue 500 ft.
Brand:|Model: 105E6Y|Part # 101-005
Wired Home's bulk Cat 5e cable features 350 MHz bandwidth for high-speed Gigabit Ethernet networks while meeting or exceeding the standards set forth by EIA/TIA 568B.2 for performance. Complies with UL and NEC riser rating requirements for vertical flame testing.
List Price$123.99
You Save50%
$62.19
Buy 4+$60.32
Part # 101-005
  • Unshielded quad twisted pair construction
  • Ideal for computer network, voice, video, sound
  • 350 MHz rating far exceeds the performance of standard 100 MHz Cat 5e
  • Spool-in-Box payout system virtually eliminates cable kinks, works with cable caddies
  • Sequential marks every two feet show remaining cable at-a-glance
  • CMR rated, UL, and C-UL listed; verified EIA/TIA 568B.2 compliant
Category 5e cable has become the standard cable type used in commercial and residential structured wire systems for telephony, computer networking, and surveillance…and more! Wired Home's bulk Cat 5e features 350 MHz bandwidth for advanced applications, including high-speed Gigabit Ethernet (1000BASE-T) networks and A/V signal transmission using baluns. Meets or exceeds the standards set forth by EIA/TIA 568B.2 for performance, as well as UL and NEC riser rating requirements for vertical flame testing.
Wired Home Cat 5e cable's packaging was designed around the Spool-in-Box payout system. This saves installers time and money by virtually eliminating performance-robbing cable kinks (common with other manufacturers' bulk Cat 5e cable) during installation. Alternatively, the internal spool may be removed to "rack-up" on a traditional cable caddy.
Specifications: • Individual conductors: 24 AWG (0.50 mm) • Nominal impedance: 100 ohms (±15 ohms) • DCR: 9 ohms/100 meters • Capacitance: 5000 pF/100 meters • Attenuation @ 350 MHz: 44.9 dB • Overall cable diameter: 5.10 mm (± 0.10 mm).
  • Cable Rating CMR Rated
  • Wire Gauge24 AWG
  • Jacket ColorBlue
  • Length500 ft.
  • BrandWired Home
  • Model105E6Y
  • Part Number101-005
  • UPC844632071522
  • Product CategoryCat 5 / Cat 6 Network Cable
    (3 Reviews)
  • Weight13.7 lbs.
View similar products to the Wired Home 105E6Y Cat 5e CMR Solid Cond 350 MHz Blue 500 ft.
in the Cat 5 / Cat 6 Network Cable product category.
Wired Home 105E6Y Cat 5e CMR Solid Cond 350 MHz Blue 500 ft. is rated 4.3333 out of 5 by 3.
Rated 4 out of 5 by from Basic Cat5e cableThe overall rating was 4 stars instead of 5 because I would have preferred a "spline" or core wire to add extra durability. As I ran the wire, I had to be careful not to let it kink. Other than that, it performs well. I used it to run Ethernet to my 3 bedrooms and I am very happy with the results. Excellent value for the price and fast shipping as well.
Date published: 2012-06-14
Rated 5 out of 5 by from Great BuyThis wire is perfect for running wires for basic security system keypads to provide for future system upgrades. Why run a simple four-wire when you can run CAT 5 for the same price.
Date published: 2010-01-03
Rated 4 out of 5 by from It worksSaved $45.00 getting it here rather than one of those big box home improvement stores.
Date published: 2009-11-16
  • 2016-02-11T06:57CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_101-005, PRD, sort_mostRecent
