073-069_ALT_0
073-069_ALT_1
White 60 LED SMD 3528 0.5m Tape Lighting Strip 12 VDC
Brand:| Model: DC-LE12121
Add cool white lighting almost anywhere with this 12 VDC, 60 white SMD 3528 LED tape strip. The flexible, durable design can be attached to many different surfaces using the aggressive adhesive affixed to the back of the strip for permanent mounting. 6000 to 6500K color temperature.
  • Perfect for illumination in home or in your car
  • Low 12 VDC power requirement
  • Aggressive backing for permanent placement and edge lighting
  • Wide 150° viewing angle, 6000 to 6500K color temperature
  • Combine with an LED controller for brightness control and lighting effects (sold separately)
073-069
Weight: 0.025 lbs.
IN STOCK
List Price$19.99
You Save50%
$9.98
Buy 4-up$9.78
Part # 073-069
This LED tape strip is built with 60 bright white surface mount 3528 LEDs per each half meter strip (19.69") for maximum brightness. LED strips are great for use as indoor strip lighting or illuminating a display case. The flexible, durable design hugs corners and can be attached to many different surfaces using the aggressive adhesive affixed to the back of the strip for permanent mounting.
Each strip is marked with cut lines for creating a custom length strip, or up to 20 miniature 1" strip segments with three LEDs per section. Each section features two solder points (voltage + and ground -) for easy daisy-chaining.
To facilitate ease of use, voltage dropping resistors are built-in: Simply connect a 12 VDC power supply (up to a 12 VDC, 3A power supply is recommended and sold separately) to the wire leads and go! Additionally, you can use either the 24 or 44-key remote control LED control unit to adjust brightness or add flashing effects (sold separately). CE and RoHS compliant.
Note: This LED strip is designed for interior use only. To use with an LED controller, connect the red lead to the black wire of the 24-key or 44-key LED control unit and the black to any of the other colors. Prior to attaching the LED strip to a surface, it is recommended that you clean the surface with alcohol and dry with a lint-free cloth.
Strip Specifications:
• Power requirements (per strip): 12 VDC, 2A
• Overall dimensions (W x L x H): 0.39" x 19.68" x 0.10" (10 x 500 x 2.5 mm)
• Segment dimensions (20 segments per strip): 1" (25.4 mm) L
• Power pigtail length: 3.8"
LED Specifications:
• LED type: SMD 3528
• Viewing angle: 150°
• Color temperature: 6000 to 6500K
• Dimensions (L x W x H): 3.5 x 2.8 x 2 mm
  • BrandParts Express
  • ModelDC-LE12121
  • Part Number073-069
  • UPC844632098406
  • Product CategoryAccent & Party Lighting
    (5 Reviews)
  • Weight0.025 lbs.
View similar products to the White 60 LED SMD 3528 0.5m Tape Lighting Strip 12 VDC
in the Accent & Party Lighting product category.
White 60 LED SMD 3528 0.5m Tape Lighting Strip 12 VDC is rated 4.2 out of 5 by 5.
Rated 1 out of 5 by from GarbageI bought 2 strips to mount under a counter. After 4 days various segments started going dim and dead. Not worth buying.
Date published: 2014-11-14
Rated 5 out of 5 by from replaces ccfl bulbWorks perfectly as a replacement for ccfl back lights. Very easy to install
Date published: 2014-02-03
Rated 5 out of 5 by from LED strips are easy to useThese LED strips light up uniformly and are are bright. They are perfect for cabinet lighting.I broke them into smaller strips and made 7 segment digits out of them for a digital clock application.
Date published: 2013-07-22
Rated 5 out of 5 by from not a bad purchase at all...Adhesive back is reasonably sticky, wide operating voltage, can be cut to any length or daisy-chained with a bit of soldering. At 12V, the LEDs are quite bright to look at but don't throw out a ton of illumination, which is acceptable at this price and package size. Certainly worth the price and they're pretty fun to play around with.
Date published: 2013-02-22
Rated 5 out of 5 by from Works as display monitor CCFL backlight replacementI had about given up on my 3 mo. out of warranty 25" CCFL backlit monitor after changing out the CCFL tubes only to discover that the inverter circuit was to blame. I now have a working monitor after dropping in two of these white LED strips (+ three 1" segments) into the top and bottom trays that previously held the CCFL tubes. I used an external 12V supply to power the strips and found the current per strip to be under .5A. It's slightly dimmer than before, but the color looks OK and there is no streaking due to the LEDs being point sources of light. It's worth a try before throwing your dead CCFL backlit monitor away!
Date published: 2012-07-17
Do you have longer versions of the strip
The RGB strips come in longer lengths, does the white only strip also come in longer lengths.
Asked by: fuhrmann
Unfortunately no, this is the only all white option we offer at this time.
Date published: 2013-04-05
Do the power requirements change if I cut the string in half?
I know that this will take up to a 12VDC 3A power supply, but if I cut the string in two and use a separate power supply for each strand, do the requirements change (i.e. should I only use a 12VDC 1.5A power supply for each half)?
Asked by: WJohnW
Yes the power requirements will differ from one length to another. It never hurts to have more current than you need, however you would be able to get away with half the power for half the length.
Date published: 2013-03-12
Do you sell an inverter or light switch to take standard 110 voltage down to the 12VDC?
Asked by: ibgarrett
These strips are deisgned to work with two other devices: a control box which the strip and power supply plugs into and the power supply itself.
Date published: 2013-02-11
how bright are these? What is the K temp? Thank you
Asked by: akagai
We do not have a brightness specification, but the color temp on these is 6000-6500K.
Answered by: Chrisf
Date published: 2012-12-27
Customer projects that include: White 60 LED SMD 3528 0.5m Tape Lighting Strip 12 VDC
Manuals / Resources
Related Products
Customers Also Bought
