Weller WLC100 Soldering Station
Brand:| Model: WLC100
The Weller® WLC100 solder station is ideal for the professional, serious hobbyist, or kit builder who demands higher performance than usual of a standard iron, but without the high cost of an industrial unit. Power is adjustable from 5 to 40 watts.
372-120
Weight: 2.3826 lbs.
IN STOCK
$45.88
Part # 372-120
The Weller® WLC100 solder station is ideal for the professional, serious hobbyist, or kit builder who demands higher performance than usual of a standard iron, but without the high cost of an industrial unit. Power is adjustable from 5 to 40 watts. Includes 40 watt pencil iron with ST3 1/8" screwdriver tip. UL approved. Replacement sponge #372-118.
  • BrandWeller
  • ModelWLC100
  • Part Number372-120
  • UPC037103059963
  • Product CategorySoldering Stations
    (18 Reviews)
  • Weight2.3826 lbs.
View similar products to the Weller WLC100 Soldering Station
in the Soldering Stations product category.
Weller WLC100 Soldering Station is rated 4.3333 out of 5 by 18.
Rated 5 out of 5 by from Value priced soldering station - good quality!Used this station as soon as I received it - put it through it's paces soldering audio cables for about 5 hours. The heat and performance was very consistent. I absolutely feel that I got my moneys worth.
Date published: 2014-11-10
Rated 5 out of 5 by from Great iron for the price.I build cords on a regular basis and it works just as it should.
Date published: 2014-05-05
Rated 5 out of 5 by from No problemsI have owned one of these for over 12 years and performed thousands of solder joints with many days where it was on for 10 hours plus a day and have had flawless performance. The only thing I wish was different is the screw that holds the tip in. It tends to be very hard to remove after hours of use. The screw not removing is the only thing that made me have to buy a new one. PE shipping seems REALLY SLOW lately.
Date published: 2013-01-23
Rated 4 out of 5 by from Weller WLC100 Review--Good ProductThis does what it is designed to do, regulate the heat for a small soldering iron. It has no temperature feedback, but this makes a good basic soldering station.I bought it because it makes an excellent holder for the iron, and the heat can be adjusted. I use this as a hobbyist, for soldering components onto printed circuit boards. The screwdriver tip they supply is too wide. I ordered the st-7, which is a conical tip that comes to small needle point, but the tip is a little too small, so I will be ordering the st-5 and st-6. These have very narrow, but flat tips. The iron takes any style of the Weller ST series soldering iron tips.Unless you plan on leaving the iron on for more than 8 hours, the plastic base of the soldering iron supplied will not melt, as another reviewer has stated. I keep mine 3/4 from maximum adjusted current/heat, plugged in for a few hours at a time, and my iron only gets a little warm to the touch, around where the base of the iron touches the holder.If you want a decent soldering iron with a holder that actually fits the iron, with adjustable temp, then this is a good product. If you need a professional soldering station that can be left on 24x7, then buy a higher end product than this one.
Date published: 2012-12-07
Rated 4 out of 5 by from Weller WLC100 ReviewIordered the WLC100 and found the temperature control unit did not regulate the iron or even allow the tip to heat up.Plugging the iron directly into the AC cord showed the iron worked fine it was the control unit that was at fault. I requested an RMA and returned the unit. At the same time Parts Express shipped me a replacement unit that works great. I have been using Weller units for 3 decades. The defective one was a rare instance.
Date published: 2012-09-13
Rated 5 out of 5 by from Best value for your money.Love the new feature of plugging the soldering iron at the side. This is my second soldering station after my first Wellar gave up after10 years of on the road and in the shop repairs.
Date published: 2012-07-02
what tip comes with it?
Asked by: lou94553
This comes with a 1/8" screwdriver tip, part number 372-123.
Date published: 2014-04-17
is there a euro(220v-240v) version?
meaning 3 round poles so it would fit to european socket? if there isnt, is it ok just to use an cheap regular adapter with this?
Asked by: eeebbr
Being a North American distributor, the vast majority of products we carry (including this one) are compatible only with 120VAC/60Hz. I'd suggest checking with your local retailer(s) for a Euro-compatible product, or using a voltage transformer such as I've linked below.
Answered by: RussR
Date published: 2014-02-18
wlc200 weller
I have a weller WLC200 and nee to use smaller tips, can I use a handle from a WLC100
Asked by: t2trains
Yes
Answered by: Sound Advice
Date published: 2012-06-16
What Replacement Tips Fit This Model? Stoc #;s?
Asked by: dc270
According to the manual, ST1 through ST8
Answered by: Bbradley
Date published: 2011-12-09
Customer projects that include: Weller WLC100 Soldering Station
