110-442_ALT_0
Wattgate 5266i-CLR Edison Connector Clear
Brand:| Model: 5266i-CLR
Wattgate's 5266i power connector is perfect as a replacement or building of your own audiophile grade power cords. Heavy-duty vinyl connector body is available in black or clear.
  • Cryogenically treated
  • Perma-Lock™ terminals
  • Accepts up to 10 AWG wire
  • Audio Grade® power connector
110-442
Weight: 0.12 lbs.
IN STOCK
$16.00
Buy 4-24 $15.32
Buy 25-up$14.11
Part # 110-442
Wattgate's 5266i power connector is perfect as a replacement or building of your own audiophile grade power cords. Heavy-duty vinyl connector body is available in black or clear. Perma-Lock™ terminals actually "lock up" the screw's threads. Heat and vibration cannot loosen the screw. This exclusive design creates a superior low resistance connector. Plug is cryogenically treated, 125 VAC, 15A rated, and accepts up to 10 gauge wire.
  • ConfigurationNEMA 5-15 Edison
  • Power Connector TypeCable Mount
  • Current Rating15A
  • BrandWattgate
  • Model5266i-CLR
  • Part Number110-442
  • UPC601431104420
  • Product CategoryAC Power Connectors
    (5 Reviews)
  • Weight0.12 lbs.
View similar products to the Wattgate 5266i-CLR Edison Connector Clear
in the AC Power Connectors product category.
Wattgate 5266i-CLR Edison Connector Clear is rated 4.4 out of 5 by 5.
Rated 3 out of 5 by from Body Screws Strip OutGenerally satisfied with the plug except for the body screws which I found to be too soft and extremely easy to strip the phillips head (3 of 4 stripped on first cable). Ended up using #4X1" stainless steel pan head screws from Lowes on the connectors for the second cable and replacing the screws on the first cable. Also found the clamping mechanism to result in an off center cable. I will probably use connectors from a different manufacturer for my next power cable build.
Date published: 2010-08-15
Rated 4 out of 5 by from Music LoverJust the product that i really needed. So full of useful features and so easy to assemble. Can't question nor doubt it's durability and reliability. Marinco makes a similar featured product for less than $8 so why pay another $4?
Date published: 2009-12-20
Rated 5 out of 5 by from Great upgrade for the price.I purchased a total of 3 of these along with upgrading my stock non-IEC power cables on my gear. It is of very good build quality but it limits you to 10-12 gauge but that is fine. The strain relief is odd in the way it clamps down on the cable and places the cable off-center when tightened down, small quirk. The conductor clamps are tight and it is very easy to insert all 3 conductors at once. Another feature thats great about most WattGates is that they are Cryo'd. $13.00 is a reasonable price for this product.
Date published: 2009-01-31
Rated 5 out of 5 by from Easy to assemble, looks great, works as it should.Good marking. I like quality of this item. Cables looks very nice. Amazing part - 110V in, 110V out :)
Date published: 2009-01-04
Rated 5 out of 5 by from a quality power cordWith this product and the same company IEC connector one is able to make a very high quality power cord. Excellent.
Date published: 2008-05-27
  • 2015-05-27T08:01CST
  • bvseo_cps, prod_bvrr, vn_cps_3.1.3
  • co_hasreviews, tv_0, tr_5
  • loc_en_US, sid_110-442, PRD, sort_mostRecent
Does this connector work with 18mm OD cable?
Asked by: HoHoHo
Hi,Based on the manufactures specifications accepting 10 AWG 3 wire and measuring a piece here, you should have no problem fitting 18mm.Plug manufactures generally build-in extra OD for wires outer jacket thickness in relation to plugs max AWG.in other words,don't try and stuff 8 AWG wire into a plug calibrated for 10 AWG tolerances and you'll be fine @ 18mm.My Best, Sal
Answered by: sal J
Date published: 2014-05-03
Clamping screw colors as they relate to hot and neutral
Aargh. I'm assembling a power cord and have an issue: I need to know how the clamping screw colors on this relate to the Wattagte 320i IEC plug. The IEC has the screws labeled L and N but this one doesn't. I'm assuming on this that silver is hot and black is neutral?
Asked by: wes in va
Black hot, Silver,neutral Green, ground
Answered by: Mr. Engineer
  • 2015-05-27T09:40CST
  • bvseo_cps, prod_bvqa, vn_cps_3.1.3
  • loc_en_US, sid_110-442, PRD, sort_recentQuestionsFirst
Customer projects that include: Wattgate 5266i-CLR Edison Connector Clear
