Clearance Item
110-439_ALT_0
Wattgate 381 Audio Grade Duplex Receptacle Outlet
Brand:| Model: 381
Why build a performance power cable only to plug it into the same receptacle that's been in use for almost 100 years? WattGate's 381 is a no-compromise solution for the AV connoisseur.
  • Cryogenic heat treat hardened contacts
  • Solid brass contact construction
  • Three step 24k gold plating process
  • Triple wiper design increases contact area
  • Superior performance over standard receptacles
110-439
Weight: 0.35 lbs.
If you are building your own audiophile power cords to improve component performance, you'll find the WattGate 381 receptacle essential. Quality of construction is top-notch, featuring glass-filled nylon front and rear housings. Mounting strap, rivets and grounding strip are gold-plated brass for the ultimate in corrosion resistance and power transfer. Installation of the 381 is simple and efficient due to rear wiring and large, #10 brass terminal screws. Terminal clamps are gold plated, solid brass and shaped to better grip the conductors. A triple-wiper design allows the plug blades to be gripped at three separate points.
Additionally, the heavy-duty contacts maximize the clamping spring-rate and ensure conductivity. All plating is accomplished through a three-part process: oxygen free copper plating, electrolysis nickel, and finally 24k gold plating. Receptacle contacts are cryogenically treated.
Receptacle is rated at 125 VAC, 20A.
  • ConfigurationNEMA 5-20
  • Power Connector TypeDuplex Receptacle
  • Current Rating20A
  • BrandWattgate
  • Model381
  • Part Number110-439
  • UPC601431104390
  • Product CategoryAC Power Connectors
    (94 Reviews)
  • Weight0.35 lbs.
View similar products to the Wattgate 381 Audio Grade Duplex Receptacle Outlet
in the AC Power Connectors product category.
Customer projects that include: Wattgate 381 Audio Grade Duplex Receptacle Outlet
