Wattgate 350i-CLR Audio Grade IEC Connector Clear
Brand:| Model: 350i-CLR
The years of development have finally produced a superior cord-end IEC. Gone are the days of wimpy, soldered contacts. The Wattgate™ 350 is here! Construction of the 350 is durable and features an elegant polycarbonate rear housing available in either black or clear.
  • Cryogenically treated
  • Perma-Lock™ terminals
  • Accepts up to 10 AWG wire
  • Audio Grade® IEC power connector
110-434
Weight: 0.3 lbs.
IN STOCK
Order Soon - Only 2 Left In Stock
$77.92
Buy 4-24 $75.87
Buy 25-up$67.14
Part # 110-434
The years of development have finally produced a superior cord-end IEC. Gone are the days of wimpy, soldered contacts. The Wattgate™ 350 is here! Construction of the 350 is durable and features an elegant polycarbonate rear housing available in either black or clear. A durable hi-temperature rated front housing is standard. Designed for a wide range of power cables, the 350's removable insert can accommodate cable diameters from 0.300" (7.62 mm) to 0.655" (16.63 mm).
Clearly marked, tightly-spaced, funnel shaped holes guide the conductors into the unique Perma-Lock™ terminals for simple installation. Perma-Lock™ terminals work in the following fashion: As the terminal screw tightens down on the contact tang, it compresses the wire underneath the tang and causes the screw to exert an upwards lift on the collar overleaf.
This lifting action "locks up" the thread on the screws. Stress on the terminals is virtually eliminated. Heat cycling and vibration cannot loosen the screw. The departure that the 350 takes from traditional IECs, lies within the contact elements themselves. Contacts on the 350 are large and designed for a high spring rate to securely grip the conductor. A three-layer plating process is also used: Oxygen free copper plating, electrolysis nickel, and finally 24k gold plating dramatically improves conductivity and prevents corrosion. Plugs are cryogenically treated, rated at 125 VAC, 15A, and accept up to 10 gauge wire.
  • ConfigurationIEC
  • Power Connector TypeCable Mount
  • Current Rating15A
  • BrandWattgate
  • Model350i-CLR
  • Part Number110-434
  • UPC601431043453
  • Product CategoryAC Power Connectors
  • Weight0.3 lbs.
View similar products to the Wattgate 350i-CLR Audio Grade IEC Connector Clear
in the AC Power Connectors product category.
Customer projects that include: Wattgate 350i-CLR Audio Grade IEC Connector Clear
