Wattgate 350i-BLK Audio Grade IEC Connector Black
Brand:| Model: 350i-BLK
The years of development have finally produced a superior cord-end IEC. Gone are the days of wimpy, soldered contacts. The Wattgate™ 350 is here! Construction of the 350 is durable and features an elegant polycarbonate rear housing available in either black or clear.
  • Cryogenically treated
  • Perma-Lock™ terminals
  • Accepts up to 10 AWG wire
  • Audio Grade® IEC power connector
110-435
Weight: 0.3 lbs.
IN STOCK
Order Soon - Only 3 Left In Stock
$77.92
Buy 4-24 $75.87
Buy 25-up$67.14
Part # 110-435
The years of development have finally produced a superior cord-end IEC. Gone are the days of wimpy, soldered contacts. The Wattgate 350 is here! The construction of the 350 is durable, featuring an elegant polycarbonate rear housing available in either black or clear with a durable hi-temperature rated front housing. The 350 has been designed to be adaptable to a wide range of power cables the removable insert can accommodate cable diameters from 0.300" (7.62 mm) to 0.655" (16.63 mm).
Installation has been further simplified due to clearly marked, tightly-spaced, funnel shaped holes to guide the conductors into the unique Perma-Lock™ terminals. The Perma-Lock terminals work in the following way: As the terminal screw tightens down on the contact tang, it compresses the wire underneath the tang, causing the screw to exert an upwards lift of the collar overleaf. This lifting action "locks up" the threads screws. Stress relieving of the terminals is virtually eliminated. Heat cycling and vibration cannot loosen the screw.
The real departure the 350 takes from the traditional IEC lies with the contact elements themselves. Their contacts are large and designed to posses a high spring rate to securely grip the connector on the component. In addition, a three-layer plating process is added: Oxygen free copper plating, electroless nickel, and finally 24k gold plating dramatically improves conductivity and prevents corrosion. Plugs are cryogenically treated, rated at 125 VAC, 15A, and accept up to 10 gauge wire.
  • ConfigurationIEC
  • Power Connector TypeCable Mount
  • Current Rating15A
  • BrandWattgate
  • Model350i-BLK
  • Part Number110-435
  • UPC601431104352
  • Product CategoryAC Power Connectors
    (1 Reviews)
  • Weight0.3 lbs.
View similar products to the Wattgate 350i-BLK Audio Grade IEC Connector Black
in the AC Power Connectors product category.
Wattgate 350i-BLK Audio Grade IEC Connector Black is rated 4.0 out of 5 by 1.
Rated 4 out of 5 by from Wattgate's Top-Line Ends Are Fabulous!Only weak area is that the entry holes for the wire could be a tad bigger, to accept 8 AWG, my standard for super high current delivery. All-in-all, A- (or 91%)..good clamp-down strength, good breakage resistance, good musicality & dynamic nuances, slightly tube-ish, yet detail is not blurred. Requires long break-in of 100-300 hours minimum for best in openness & transparency.
Date published: 2007-12-27
Customer projects that include: Wattgate 350i-BLK Audio Grade IEC Connector Black
