Wattgate 350i Ag HC Silver Plated IEC Connector 20A
Wattgate 350i Ag HC Silver Plated IEC Power Connector 20A
Brand:| Model: 350i AG HC
WattGate's 350i Ag HC IEC plug is the answer for those seeking perfect power performance. Fast, simple installation and loss-less performance were the focus of the 350i's design.
  • 20A rated
  • Perma-Lockā„¢ terminals
  • Three step silver plating process
  • Superior performance over conventional plugs
110-429
Weight: 0.2801 lbs.
IN STOCK
Order Soon - Only 3 Left In Stock
$97.82
Buy 4-up$92.93
Part # 110-429
WattGate's 350i Ag HC IEC plug is the answer for those seeking perfect power performance. Fast, simple installation and loss-less performance were the focus of the 350i's design. Superior construction of the 350i Ag HC features an elegant polycarbonate rear housing in a cobalt blue with a glass filled nylon front housing. The removable insert can accommodate cable diameters from 0.300" (7.62 mm) to 0.655" (16.63 mm). Installation is simplified due to color coded, tightly-spaced, funnel shaped holes to guide the conductors into the unique Perma-Lock™ terminals. Perma-Lock™ terminals work in the following way: As the terminal screw tightens down on the contact tang, it compresses the wire underneath the tang, causing the screw to exert an upward lift of the collar overleaf. This lifting action "locks up" the threads screws. Stress on the terminals is virtually eliminated. Heat cycling and vibration cannot loosen the screw. The real secret behind the 350i Ag HC lies in the contact elements themselves. Super thick contact tangs are used along with a three-layer plating process: Oxygen free copper plating, electrolysis nickel, and finally silver plating dramatically improves conductivity and prevents corrosion. Plug is cryogenically treated, rated to 120 VAC, 20A, and accepts up to 10 gauge wire.
  • ConfigurationIEC C19
  • Power Connector TypeCable Mount
  • Current Rating20A
  • BrandWattgate
  • Model350i AG HC
  • Part Number110-429
  • UPC844632055805
  • Product CategoryAC Power Connectors
  • Weight0.2801 lbs.
View similar products to the Wattgate 350i Ag HC Silver Plated IEC Power Connector 20A
in the AC Power Connectors product category.
Customer projects that include: Wattgate 350i Ag HC Silver Plated IEC Power Connector 20A
