Wattgate 330i-CLR Audio Grade Edison Connector Clear
Brand:| Model: 330i-CLR
If you are searching for a simple way to make a big improvement in your audio or home theater system, look no further. WattGatte's 330i is designed for fast, simple installation and pristine performance.
  • Cryogenically treated
  • Super thick contact tangs
  • Three-layer 24k gold plating process
  • Instantly provides superior performance over conventional plugs
110-436
Weight: 0.3 lbs.
IN STOCK
$77.92
Buy 4-24 $75.87
Buy 25-up$70.21
Part # 110-436
If you are searching for a simple way to make a big improvement in your audio or home theatre system, look no further. The WattGate™ 330 has been designed for fast, simple installation and worry-free performance. The construction of the 330 is built to last and features an elegant polycarbonate rear housing available in either black or clear with a durable nylon-tough front housing. The 330 has been designed to be adaptable to a wide range of power cables the removable insert can accommodate cable diameters from 0.300" (7.62 mm) to 0.655" (16.63 mm).
Installation has been further simplified due to color coded, tightly-spaced, funnel shaped holes to guide the conductors into the unique Perma-Lock™ terminals. The Perma-Lock™ terminals work in the following way: As the terminal screw tightens down on the contact tang, it compresses the wire underneath the tang, causing the screw to exert an upwards lift of the collar overleaf. This lifting action "locks up" the threads screws. Stress relieving of the terminals is virtually eliminated. Heat cycling and vibration cannot loosen the screw.
The real secret behind the 330 lies with the contact elements themselves. Super thick contact tangs are used along with a three-layer plating process: Oxygen free copper plating, electroless nickel, and finally 24k gold plating dramatically improves conductivity and prevents corrosion. Plugs are 125V, 15 amp and can accept up to10 gauge wire.
  • ConfigurationNEMA 5-15 Edison
  • Power Connector TypeCable Mount
  • Current Rating15A
  • BrandWattgate
  • Model330i-CLR
  • Part Number110-436
  • UPC601431104369
  • Product CategoryAC Power Connectors
  • Weight0.3 lbs.
View similar products to the Wattgate 330i-CLR Audio Grade Edison Connector Clear
in the AC Power Connectors product category.
Customer projects that include: Wattgate 330i-CLR Audio Grade Edison Connector Clear
