Wattgate 330i-BLK Audio Grade Edison Connector Black
Wattgate 330i Audio Grade Edison Connector Black
Brand:| Model: 330i-BLK
If you are searching for a simple way to make a big improvement in your audio or home theater system, look no further. WattGatte's 330i is designed for fast, simple installation and pristine performance.
  • Cryogenically treated
  • Super thick contact tangs
  • Three-layer 24k gold plating process
  • Instantly provides superior performance over conventional plugs
110-437
Weight: 0.3 lbs.
IN STOCK
Order Soon - Only 3 Left In Stock
$77.92
Buy 4-24 $75.87
Buy 25-up$70.21
Part # 110-437
If you are searching for a simple way to make a big improvement in your audio or home theatre system, look no further. The WattGate™ 330I has been designed for fast, simple installation and worry-free performance. The construction of the 330I is built to last and features an elegant polycarbonate rear housing available in either black or clear with a durable nylon-tough front housing. The 330I has been designed to be adaptable to a wide range of power cables the removable insert can accommodate cable diameters from 0.300" (7.62 mm) to 0.655" (16.63 mm).
Installation has been further simplified due to color coded, tightly-spaced, funnel shaped holes to guide the conductors into the unique Perma-Lock™ terminals. The Perma-Lock™ terminals work in the following way: As the terminal screw tightens down on the contact tang, it compresses the wire underneath the tang, causing the screw to exert an upwards lift of the collar overleaf. This lifting action "locks up" the threads screws. Stress relieving of the terminals is virtually eliminated. Heat cycling and vibration cannot loosen the screw.
The real secret behind the 330I lies with the contact elements themselves. Super thick contact tangs are used along with a three-layer plating process: Oxygen free copper plating, electroless nickel, and finally 24k gold plating dramatically improves conductivity and prevents corrosion. Plugs are 125V, 15 amp and can accept up to10 gauge wire.
  • ConfigurationNEMA 5-15 Edison
  • Power Connector TypeCable Mount
  • Current Rating15A
  • BrandWattgate
  • Model330i-BLK
  • Part Number110-437
  • UPC601431104376
  • Product CategoryAC Power Connectors
    (3 Reviews)
  • Weight0.3 lbs.
View similar products to the Wattgate 330i Audio Grade Edison Connector Black
in the AC Power Connectors product category.
Wattgate 330i Audio Grade Edison Connector Black is rated 3.3333 out of 5 by 3.
Rated 1 out of 5 by from Foolish productMy professional opinion:This plug is a glorified Pass and Seymour PS515PCLB available in Home Depot for $9.00There is NO technical reason why this plug will make your equipment sound better!
Date published: 2013-06-30
Rated 5 out of 5 by from Power up the wazoo!And this is the baby to do it with. I highly recommend the Wattgate Edison Clear connector, and watch the action in real time. (don't worry, it's not true what they say about the cataracts; at least it hasn't been proven yet)
Date published: 2009-10-26
Rated 4 out of 5 by from Connector for High-End Power CordIf you are looking to build a high-end power cord and have quality wires to match it to, then this connector will do the job just fine. You won't see this kind of connector on commercial power cords costing less than $500. A good buy if you require the best.
Date published: 2009-10-20
  • 2015-03-03T07:21CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_110-437, PRD, sort_mostRecent
Customer projects that include: Wattgate 330i Audio Grade Edison Connector Black
