Wattgate 330i Ag-BLUE Silver Plated Edison Connector
Wattgate 330i Ag-BLUE Silver Plated Edison Power Plug Connector
Brand:| Model: 330i AG
WattGate's 330i Ag Silver Edison plug is the answer for those seeking perfect power performance. Fast, simple installation and loss-less performance were the focus of the 330i's design.
  • Cobalt blue housing
  • Cryogenically treated
  • Perma-Lockā„¢ terminals
  • Three-layer silver plating process
110-427
Weight: 0.2801 lbs.
IN STOCK
$77.92
Buy 4-up$74.02
Part # 110-427
WattGate's 330i Ag Silver Edison plug is the answer for those seeking perfect power performance. Fast, simple installation and loss-less performance were the focus of the 330i's design. Superior construction of the 330i Ag features an elegant polycarbonate rear housing in a cobalt blue with a glass filled nylon front housing. The removable insert can accommodate cable diameters from 0.300" (7.62 mm) to 0.655" (16.63 mm). Installation is simplified due to color coded, tightly-spaced, funnel shaped holes to guide the conductors into the unique Perma-Lock™ terminals. Perma-Lock™ terminals work in the following way: As the terminal screw tightens down on the contact tang, it compresses the wire underneath the tang, causing the screw to exert an upward lift of the collar overleaf. This lifting action "locks up" the threads screws. Stress on the terminals is virtually eliminated. Heat cycling and vibration cannot loosen the screw. The real secret behind the 330i Ag lies in the contact elements themselves. Super thick contact tangs are used along with a three-layer plating process: Oxygen free copper plating, electrolysis nickel, and finally silver plating dramatically improves conductivity and prevents corrosion. Plug is cryogenically treated, rated at 125 VAC, 15A, and accepts up to 10 gauge wire.
  • ConfigurationNEMA 5-15 Edison
  • Power Connector TypeCable Mount
  • Current Rating15A
  • BrandWattgate
  • Model330i AG
  • Part Number110-427
  • UPC844632055782
  • Product CategoryAC Power Connectors
    (2 Reviews)
  • Weight0.2801 lbs.
View similar products to the Wattgate 330i Ag-BLUE Silver Plated Edison Power Plug Connector
in the AC Power Connectors product category.
Wattgate 330i Ag-BLUE Silver Plated Edison Power Plug Connector is rated 4.5 out of 5 by 2.
Rated 4 out of 5 by from Silver Wattgate's For Vacuum Tube GEAR!Allow for 50-100 hours of break-in for best openess & transparency. Very interesting sonics that will improve any system, one order of magnitude!
Date published: 2008-12-20
Rated 5 out of 5 by from outstandingI am a electronic tech and I worked for Bell South Telephone for many years so I know what kind of difference a simple connection can make on small amounts of electricity whether AC or DC. The experience I gained from working with -48 vdc phone lines over many many miles of 18ga. to 28ga. of solid copper wire (most used 24ga.). You let just a little of anything get in that connection or let it not be tight and guess what noise and lots of it. To most people who listen to audio, power cords and their connectors are the lest of their concerns if at all. What they don't understand is garbage in and you will get garbage out. There are 6 important connections on this plug. The inside connections use top quality connectors fitting very tight and they used very good materials and the outside posts make the fit tight between the plug and the plug-in again with the best materials. Great job!
Date published: 2007-07-08
  • 2015-03-29T07:56CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_110-427, PRD, sort_mostRecent
Customer projects that include: Wattgate 330i Ag-BLUE Silver Plated Edison Power Plug Connector
