Wattgate 320i-CLR IEC Connector Clear
Wattgate 320i CLEAR IEC Power Connector Clear
Brand:| Model: 320i CLEAR
Wattgate's 320 IEC connector is perfect as a replacement or building of your own audiophile grade power cords. Heavy-duty vinyl connector body is available in black or clear.
  • Cryogenically treated
  • Perma-Lock™ terminals
  • Accepts up to 10 AWG wire
  • Audio Grade® IEC connector
110-430
Weight: 0.12 lbs.
IN STOCK
$22.90
Buy 4-24 $21.50
Buy 25-up$19.50
Part # 110-430
Wattgate's 320 IEC connector is perfect as a replacement or building of your own audiophile grade power cords. Heavy-duty vinyl connector body is available in black or clear. Perma-Lock™ terminals actually "lock up" the screw's threads. Heat and vibration cannot loosen the screw. This exclusive design creates a superior low resistance connector. Plug is cryogenically treated, rated at 125 V, 15A, and accepts up to 10 gauge wire.
  • ConfigurationIEC
  • Power Connector TypeCable Mount
  • Current Rating15A
  • BrandWattgate
  • Model320i CLEAR
  • Part Number110-430
  • UPC601431104307
  • Product CategoryAC Power Connectors
    (14 Reviews)
  • Weight0.12 lbs.
View similar products to the Wattgate 320i CLEAR IEC Power Connector Clear
in the AC Power Connectors product category.
Wattgate 320i CLEAR IEC Power Connector Clear is rated 3.8571 out of 5 by 14.
Rated 5 out of 5 by from Great product, makes a power cable look stellar.I wanted to build an inexpensive cable and chose this item to start my project. I went with a 10ga. power cable supplied by my local big box hardware store and set out on my build. I used silver techflex sleeving and tied up the ends with black heat shrink tubing. I think it came out quite nice and didn't have the screws stripping out mentioned on other reviews. I would definitely consider using these pieces from Wattgate again in the future. I thought it was money well spent and fit the bill perfectly.
Date published: 2015-05-25
Rated 1 out of 5 by from not worth the moneyvery poor quality ,not worth the money. cheaply made .
Date published: 2013-05-30
Rated 5 out of 5 by from Replaced a right angle plugI bought the Wattgate 320i-CLR IEC Connector Clear to replace the original equipment cord end on an installed gas wall heater. The supplied power cord had an end which turned the cord the wrong direction. The cord was too long and the color didn't match the room. I bought a heavy duty extension cord. I cut the end off and replaced it with the Wattgate 320i-CLR IEC Connector. It was a quick exchange. The new connector is well made and easy to use - just a bit expensive.
Date published: 2012-01-02
Rated 2 out of 5 by from Stripped threads on 1 of 4This is a nice looking product and came as OEM on my Nordost power cords. I needed more connectors as I shortened cords and made more shorter cords. One ground connection screw threads stripped under modest hand torque. I consider this unacceptable.
Date published: 2011-11-18
Rated 3 out of 5 by from Body Screws Strip OutGenerally satisfied with the plug except for the body screws which I found to be too soft and extremely easy to strip the phillips head (3 of 4 stripped on first cable). Ended up using #4X1" stainless steel pan head screws from Lowes on the connectors for the second cable and replacing the screws on the first cable. Also found the clamping mechanism to result in an off center cable. I will probably use connectors from a different manufacturer for my next power cable build.
Date published: 2010-08-15
Rated 5 out of 5 by from Let us have ruby or other colour see through plastThe use of see through plastic is not only a thing of beauty, it is practical because you can see the condition of the internal wiring. However, I have one re3quest, that these see through plugs and sockets would be made available in see through colours. One power cable is made with red see through ruby looking plastic. Could you please manufacture such a plug? I would buy it.
Date published: 2009-12-09
  • 2015-07-03T07:48CST
  • bvseo_cps, prod_bvrr, vn_cps_3.1.5
  • co_hasreviews, tv_0, tr_14
  • loc_en_US, sid_110-430, PRD, sort_mostRecent
Does this connector work with 18mm OD cable?
Asked by: HoHoHo
The cable entry diameter is .656" which is 16.66mm.
Date published: 2013-01-23
  • 2015-07-03T09:43CST
  • bvseo_cps, prod_bvqa, vn_cps_3.1.5
  • loc_en_US, sid_110-430, PRD, sort_recentQuestionsFirst
Customer projects that include: Wattgate 320i CLEAR IEC Power Connector Clear
