Wattgate 320i Black IEC AC Power Connector
Brand:|Model: 320i BLACK|Part # 110-432
Wattgate's 320i power connector is perfect as a replacement or building of your own audiophile grade power cords. Heavy-duty vinyl connector body is available in black or clear.
$22.90
Buy 4-24 $21.50
Buy 25+$19.50
Part # 110-432
  • Cryogenically treated
  • Perma-Lock™ terminals
  • Accepts up to 10 AWG wire
  • Glass filled high temperature nylon front housing
  • Large high spring-rate contacts
  • Stainless hardware
  • 15A/125VAC, 10A/250VAC
Wattgate's 320i power connector is perfect as a replacement or building of your own audiophile grade power cords. Heavy-duty vinyl connector body is available in black or clear. Perma-Lock™ terminals actually "lock up" the screw's threads. Heat and vibration cannot loosen the screw. This exclusive design creates a superior low resistance connector. Plug is cryogenically treated, 125 VAC, 15A rated (250 VAC, 10A), and accepts up to 10 gauge wire.
  • ConfigurationIEC
  • Power Connector TypeCable Mount
  • Current Rating15A
  • BrandWattgate
  • Model320i BLACK
  • Part Number110-432
  • UPC601431104000
  • Product CategoryAC Power Connectors
    (18 Reviews)
  • Weight0.3 lbs.
View similar products to the Wattgate 320i Black IEC AC Power Connector
in the AC Power Connectors product category.
Wattgate 320i Black IEC AC Power Connector is rated 4.4444 out of 5 by 18.
Rated 5 out of 5 by from This review is for Wattgate 320i and 5266iAn audiophile friend of mine turned me onto making my own power cables for a fraction of the price of premade ones, so I figured I’d give it a shot. He has a few “recipes” for quality cables and they all started with these connectors. Quite frankly I just wanted a low gauge high quality cable for my power amp (Adcom 5802) so I wasn’t interested in “braiding” my own, standard SJ type cable would be fine with me. I don’t have a listening room and the majority of my equipment is Mid-Fi at best with the exclusion of my Eggleston Andra “clones” (Dynaudio drivers, subs, Scanspeak Tweeters (I think) etc etc).Now that you know what my goals were and what I’m working with, let me tell you about the connectors. I originally bought 2 of each of the connectors and 25ft of 10-3 Carol from PE. Come to find out, 10-3 won’t fit unless you remove the inner wire clamp or strip the wire past the rubber housing. This was a No-No for me. I wanted the inner clamp to interface with the outer rubber housing. Since I can be impatient at times, I ran to the local hardware store with my plugs in hand to see what would fit. Turns out that 12-3 works *perfectly*. Why I even thought I needed 10-3 in the first place was beyond me. Even 12-3 is over kill IMO. The inner connectors are metal on metal and clamp nice and tight. The 4 other housing screws are into plastic, but you could feel when the plastic was starting to stress under tension and that’s when I would let off. Over all I’m very happy with my purchase and I’ll be making more when I upgrade my components further.For reference- I would strip the outer casing at about 3.4cm and the inner wire about 1.5cm. That would make it so the outer clamp would interface with the black outer tube (in case someone pulled the plug out by the cord and not the plug) and no stripped wire would be showing when they were put into the “clamp holes”.
Date published: 2015-07-28
Rated 4 out of 5 by from A good value IEC plugI bought this to build a DIY audiophile power cord. It works great and easy to install.
Date published: 2014-02-11
Rated 5 out of 5 by from Great partThis was exactly what I was looking for. It was a great price and it was deliveredwithin 7 days . Works great
Date published: 2014-01-23
Rated 3 out of 5 by from Godd, but could be betterWent with Wattgate because of the cryo treatment or else I would just have gone with the low-end Marinco connectors.The wire clamp screw came too far out and jammed on an angle, causing the screw to cross thread. Eventually I got it locked in, but not ultra secure.
Date published: 2013-01-10
Rated 4 out of 5 by from almost therea good value. grips wire great without damage. now if they just could make it with a tighter grip and extend the female conductors towards the tip of the body more and then make a cable clamp that better centers the cable it would be great!
Date published: 2012-11-25
Rated 5 out of 5 by from Wattgate 320i-BLK IEC Connector BlackThe connector is solid "gas-tight" after assembly. The component side connections are tension loaded and really grab.
Date published: 2012-03-01
  • 2016-02-12T06:29CST
  • co_hasreviews, tv_0, tr_18
  • loc_en_US, sid_110-432, PRD, sort_mostRecent
Will this cord end  ( lock )  onto the male end of my Vizio TV  ?
Asked by: sailersteve
No, this does not have provisions for a locking IEC jack.
Date published: 2014-12-08
Hi, I want to use this plug for a DIY project, but my wire is 3 conductor/10 gauges. I want to be sure that is fit ?. I dont know exactly the outside rubber jacket diameter but i think i could do some modification.
Asked by: JOCP
Yes this will accept 10 gauge cable.
Date published: 2014-11-28
  • 2016-02-12T07:13CST
  • loc_en_US, sid_110-432, PRD, sort_recentQuestionsFirst
