V&S #581 Foam & Fabric Spray Glue Adhesive 12 oz.
Brand:|Model: #581|Part # 340-096
V&S #581 fast drying spray adhesive is specially formulated for bonding flexible foams and fabrics to wood, metal, fiberboard, and other textile materials.
ShippingGROUND ONLY
$6.90
Buy 12+$5.95
Part # 340-096
  • Fast tack
  • Controlled lace type spray pattern reduces overspray
  • Non-dimpling glue lines
  • Excellent heat resistance
Industrial grade, this fast drying aerosol spray adhesive is specially formulated for bonding foams and fabrics to wood, metal, fiberboard, and other textile materials. Bonds on contact. Works well with acoustic damping foams, trunk liners, and speaker cabinet carpet. 581 fabric and foam spray adhesive has a "controlled lace" type spray pattern which reduces overspray. Contains 12 oz. Made in the USA. NOTE: Not recommended for vinyl bonding or installation of vehicle headliners.
  • BrandV&S
  • Model#581
  • Part Number340-096
  • UPC050393005816
  • Product CategorySpray Adhesive & Glue
    (23 Reviews)
  • Weight1.32 lbs.
View similar products to the V&S #581 Foam & Fabric Spray Glue Adhesive 12 oz.
in the Spray Adhesive & Glue product category.
V&S #581 Foam & Fabric Spray Glue Adhesive 12 oz. is rated 4.4783 out of 5 by 23.
Rated 1 out of 5 by from A Total DisasterI carefully covered two new MDF speaker cabinets with Tolex using the 581 adhesive exactly according to the directions, sprayed it on carefully and generously, making sure to get good coverage at the seams, etc., rolled the tolex down with a laminate roller and everything looked good. After about 6 months the material is completely pulling away from the cabinets. There is a sort of oily sticky residue on the back of the Tolex and it will not stick back down at all. I'm going to have to completely strip the cabinets and start all over with new Tolex. Needless to say, this is going to be a huge and difficult job when I should have been done and able to just relax. I'm a photographer and have used tons of 3M Spray Mount and other adhesives and have never run into anything like this.
Date published: 2015-08-03
Rated 5 out of 5 by from Great StuffThis stuff really works great I'm building a big cabinet and I'm using it for adhesive to glue the carpet covering to the wood and it 's really looking nice
Date published: 2015-03-21
Rated 3 out of 5 by from Caveat EmptorI bought this adhesive to use to apply black Tolex to a re-furbished Fender Bassman box. Right on the can it says "do not use on vinyl materials" its a foam adhesive. That warning should have been in the Product Description. Someone's going to buy it because it costs about a third less than anything else, and mess up their project. Although it may have other uses, apparently, the solvents soften vinyl. PE came to my rescue. They sent me a free can of the correct adhesive. PE rocks !! 5 STARS for PE, 3 STARS for the glue.
Date published: 2015-01-29
Rated 5 out of 5 by from great stuffI have built several speaker boxes for car audio and I have always used the super 77 stuff and been satisfied. .. I bought this stuff based on the reviews and they were right! This stuff is stronger and it sets faster than the other.. not to mention it's cheaper! Bottom line I am definitely buy this stuff from now on!
Date published: 2014-08-27
Rated 5 out of 5 by from This spray works great.Better spray adhesive you can buy for the money. 5 Stars!!!!!!!!
Date published: 2013-07-22
Rated 5 out of 5 by from works as advertisedthis stuff works exactly as advertised, its really sticky. Just spray it on, and wait 3-4 minutes for it to start to get tacky, and then put your materials together - you're done. Have used it for attaching grill cloth to wooden frames, felt to baffles and dampening material to inside of speaker enclosures - worked perfectly in every case.
Date published: 2013-03-18
  • 2016-05-04T06:24CST
  • bvseo_cps, prod_bvrr, vn_cps_3.2.0
  • co_hasreviews, tv_0, tr_23
  • loc_en_US, sid_340-096, PRD, sort_mostRecent
Is this product safe to use on EPO Foam?
Asked by: Shoestring 1958
It is rated by the manufacturer to work with latex or urethane foams.
Answered by: GregT
Date published: 2016-05-03
Would this be good for fabric? I'm trying to adhere creases on my convertible top?
Asked by: Gatorgirl68
Yes this product works well on fabric.
Date published: 2015-10-26
How long does the spray exactly dry?
Asked by: T0nieboy56
There is no exact dry time on the can, but having used this product it dries to a tack within a few minutes and once both glued surfaces are applied to each other it will be very difficult to remove them immediately. I would allow an hour or so for full cure, although handling is possible within minutes.
Date published: 2014-11-10
Spray on which side?
I want to glue foam to ABS. Do I spray this on the foam or on the ABS? Thanks!
Asked by: A Parts Express shopper
Should be both. Read the instructions on the can and they will tell you what to do.
Date published: 2012-11-19
When applying does this come out as a fan spray or a stream?
Asked by: Takeformstudios
This product exits the can in a vertical fan pattern, definitely not a sharp stream.
Answered by: RussR
Date published: 2011-08-22
  • 2016-05-04T06:59CST
  • bvseo_cps, prod_bvqa, vn_cps_3.2.0
  • co_hasquestionsanswers, tq_5
  • loc_en_US, sid_340-096, PRD, sort_recentQuestionsFirst
