Visaton W300S-4 12" Woofer with Treated Paper Cone 4 Ohm
Brand:|Model: W300S - 4|Part # 292-578
The 9040 W300S 12" woofer from Visaton delivers amazing bass performance not normally found at this price point, combined with smooth frequency response and 14 mm of Xmax.
Part # 292-578
  • 5.25 mm of Xmax and ±14 mm excursion limit combined with 92 dB sensitivity and low 23 Hz Fs
  • Amazing flat response all the way up to 1,800 Hz
  • Perfect for use as a home or car audio subwoofer
  • Bumped back plate for extreme excursion moments
Visaton's 9040 W300S 12" woofer features a coated paper cone, durable rubber surround, and a bumped back plate to allow all 5.25 mm of Xmax to be used with an excursion limit of ±14 mm. The W300S is a departure from most modern subwoofers that focus on extreme power handling and Xmax while sacrificing sensitivity, not only do you get high sensitivity and a low Fs, you also get a motor design that features a Qts of 0.25 for truly articulate, fast bass. Perfect for use in three-way and four-way speaker systems. 4-ohm impedance also makes it a great choice for use as a home or car audio subwoofer.
Note: For best bass performance, install the W300S into one of the following cabinets:
• A 2.47 cubic foot cabinet tuned to 36 Hz with two 2-1/2" diameter ports that are 5-3/4" long.
• A 3.53 cubic foot cabinet tuned to 32 Hz with two 2-1/2" diameter ports that are 4-3/4" long.
• A 5.30 cubic foot cabinet tuned to 29 Hz with two 2-1/2" diameter ports that are 3-15/16" long.
  • Nominal Diameter12"
  • Power Handling (RMS)150 Watts
  • Power Handling (max)200 Watts
  • Impedance4 ohms
  • Frequency Response23 to 4,200 Hz
  • Sensitivity92 dB 1W/1m
  • Voice Coil Diameter2"
  • Resonant Frequency (Fs)23 Hz
  • DC Resistance (Re)3.5 ohms
  • Voice Coil Inductance (Le)1.1 mH
  • Mechanical Q (Qms)1.6
  • Electromagnetic Q (Qes)0.3
  • Total Q (Qts)0.25
  • Compliance Equivalent Volume (Vas)10.6 ft.³
  • Maximum Linear Excursion (Xmax)5.25 mm
  • Cone MaterialTreated Paper
  • Surround MaterialRubber
  • Overall Outside Diameter13.07"
  • Baffle Cutout Diameter10.91"
  • Depth5.28"
  • Sealed Volume1.13 ft.³
  • Sealed F372 Hz
  • Vented Volume2.19 ft.³
  • Vented F347 Hz
  • BrandVisaton
  • ModelW300S - 4
  • Part Number292-578
  • UPC4007540090405
  • Product CategoryWoofers
  • Weight11.65 lbs.
View similar products to the Visaton W300S-4 12" Woofer with Treated Paper Cone 4 Ohm
