Visaton W250S-8 10" Woofer with Treated Paper Cone 8 Ohm
Brand:|Model: W250S - 8|Part # 292-576
The 9035 W250S 10" woofer from Visaton delivers amazing performance not normally found in drivers this size at this price point. A low Qts allows you to get very deep bass in a reasonably sized ported enclosure.
$77.56
Buy 4+$70.51
Part # 292-576
  • Very flat frequency response for easy system integration
  • Great for use as a HiFi woofer or as a subwoofer
  • Great sensitivity combined with low Fs and Qts for high performance
Visaton's 9035 W250S 10" woofer features a coated paper cone, durable rubber surround, and a bumped back plate to allow all 5 mm of Xmax to be used with an excursion limit of ±7 mm. A balanced design approach between sensitivity, smooth frequency response (cross it over as high as 2,500 Hz), and extended bass allows this driver to be used as a high-output HiFi woofer in three-way speaker systems or as a subwoofer.
Note: For best bass performance, install the W250S into one of the following cabinets:
• A 1.77 cubic foot cabinet tuned to 43 Hz with two 2-1/2" diameter ports that are 5-3/4" long.
• A 2.47 cubic foot cabinet tuned to 39 Hz with two 2-1/2" diameter ports that are 5-3/4" long.
• A 3.53 cubic foot cabinet tuned to 34 Hz with two 2-1/2" diameter ports that are 3-15/16" long.
  • Nominal Diameter10"
  • Power Handling (RMS)100 Watts
  • Power Handling (max)150 Watts
  • Impedance8 ohms
  • Frequency Response31 to 5,500 Hz
  • Sensitivity90 dB 1W/1m
  • Voice Coil Diameter1.5"
  • Resonant Frequency (Fs)31 Hz
  • DC Resistance (Re)6.6 ohms
  • Voice Coil Inductance (Le)1.5 mH
  • Mechanical Q (Qms)1.88
  • Electromagnetic Q (Qes)0.39
  • Total Q (Qts)0.32
  • Compliance Equivalent Volume (Vas)4.27 ft.³
  • Maximum Linear Excursion (Xmax)5 mm
  • Cone MaterialTreated Paper
  • Surround MaterialRubber
  • Overall Outside Diameter11.14"
  • Baffle Cutout Diameter9.2"
  • Depth4.41"
  • Sealed Volume0.8 ft.³
  • Sealed F376 Hz
  • Vented Volume1.65 ft.³
  • Vented F347 Hz
  • BrandVisaton
  • ModelW250S - 8
  • Part Number292-576
  • UPC4007540090351
  • Product CategoryWoofers
    (1 Reviews)
  • Weight7.716 lbs.
View similar products to the Visaton W250S-8 10" Woofer with Treated Paper Cone 8 Ohm
