Visaton W200S-4 8" Woofer with Treated Paper Cone 4 Ohm
Brand:|Model: W200S - 4|Part # 292-570
The 9029 W200S 8" woofer from Visaton delivers amazing performance not normally found in drivers this size at this price point. A low Qts allows you to get very deep bass in a reasonably sized ported enclosure.
List Price$72.58
You Save15%
Buy 4+$56.22
Part # 292-570
  • High-value HiFi woofer
  • 3.5 mm of Xmax and a ±10 mm excursion limit means you can use this as a subwoofer
  • Super-low 29 Hz Fs and 0.35 Qts specifications
  • Deep bass in a moderate-sized enclosure
  • 4-ohm impedance for use as a car audio subwoofer
Visaton's 9029 W200S 8" woofer features a coated paper cone, durable rubber surround, and a bumped back plate to allow all 3.5 mm of Xmax to be used with an excursion limit of ±10 mm. A balanced design approach between sensitivity, smooth frequency response (cross it over as high as 3,000 Hz), and extended bass allows this driver to be used as a woofer in two and three-way speaker systems or as a subwoofer.
Note: For best bass performance, install the W200S into one of the following cabinets:
• A 0.53 cubic foot sealed cabinet (F3 will be 70 Hz with a Qtc of 0.7).
• A 0.71 cubic foot cabinet tuned to 45 Hz with a 2" diameter port that is 5-1/2" long.
• A 1.06 cubic foot cabinet tuned to 39 Hz with a 2" diameter port that is 4-3/8" long.
• A 1.77 cubic foot cabinet tuned to 33 Hz with a 2-1/2" diameter port that is 5-1/8" long.
  • Nominal Diameter8"
  • Power Handling (RMS)75 Watts
  • Power Handling (max)115 Watts
  • Impedance4 ohms
  • Frequency Response29 to 6,000 Hz
  • Sensitivity86 dB 1W/1m
  • Voice Coil Diameter1.375"
  • Resonant Frequency (Fs)29 Hz
  • DC Resistance (Re)3.4 ohms
  • Voice Coil Inductance (Le)1.5 mH
  • Mechanical Q (Qms)3.99
  • Electromagnetic Q (Qes)0.38
  • Total Q (Qts)0.35
  • Compliance Equivalent Volume (Vas)2.3 ft.³
  • Maximum Linear Excursion (Xmax)3.5 mm
  • Cone MaterialTreated Paper
  • Surround MaterialRubber
  • Overall Outside Diameter9.13"
  • Baffle Cutout Diameter7.25"
  • Depth3.46"
  • Sealed Volume0.51 ft.³
  • Sealed F366 Hz
  • Vented Volume1.13 ft.³
  • Vented F339 Hz
  • BrandVisaton
  • ModelW200S - 4
  • Part Number292-570
  • UPC4007540090290
  • Product CategoryWoofers
    (2 Reviews)
  • Weight3.624 lbs.
View similar products to the Visaton W200S-4 8" Woofer with Treated Paper Cone 4 Ohm
