Visaton W170S-8 6.5" Woofer with Treated Paper Cone 8 Ohm
Brand:|Model: W170S - 8|Part # 292-568
The 9025 W170S 6.5" woofer from Visaton delivers amazing performance not normally found in drivers this size at this price point. This speaker works equally well as a subwoofer, woofer, midbass... even as a midrange!
List Price$46.79
You Save10%
Buy 4+$38.38
Part # 292-568
  • Extremely well balanced woofer
  • 4.25 mm of Xmax and ±10 mm excursion limit for use as a small subwoofer
  • Easy to design into many different speaker systems
  • Amazing bang-for-the-buck performance
Visaton's 9025 W170S 6-1/2" woofer features a coated paper cone, durable rubber surround, and a bumped back plate to allow all 4.25 mm of Xmax to be used with an excursion limit of ±10 mm. A very balanced and extended frequency response allows the W170S to be used as a woofer in small two-way speakers or a midbass/midrange in three-way speakers, with a crossover point as high as 6,800 Hz, or even as a small form-factor subwoofer! This allows you to build a surround sound system with large speakers for front and left, while maintaining the same voicing in smaller surround satellite speakers.
Note: For best bass performance, install the W170S into one of the following cabinets:
• A 0.71 cubic foot sealed cabinet (F3 will be 57 Hz with a Qtc of 0.74).
• A 0.71 cubic foot cabinet tuned to 44 Hz with a 2" diameter port that is 5-1/2" long
• A 1.06 cubic foot cabinet tuned to 39 Hz with a 2-1/2" diameter port that is 4-3/4" long.
• A 1.77 cubic foot cabinet tuned to 33 Hz with a 2-1/2" diameter port that is 5-7/8" long.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)50 Watts
  • Power Handling (max)80 Watts
  • Impedance8 ohms
  • Frequency Response36 to 8,000 Hz
  • Sensitivity86 dB 1W/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)36 Hz
  • DC Resistance (Re)5.9 ohms
  • Voice Coil Inductance (Le)1.2 mH
  • Mechanical Q (Qms)2.43
  • Electromagnetic Q (Qes)0.66
  • Total Q (Qts)0.52
  • Compliance Equivalent Volume (Vas)1.34 ft.³
  • Maximum Linear Excursion (Xmax)4.25 mm
  • Cone MaterialTreated Paper
  • Surround MaterialRubber
  • Overall Outside Diameter7.36"
  • Baffle Cutout Diameter5.83"
  • Depth2.91"
  • Sealed Volume0.94 ft.³
  • Sealed F355 Hz
  • Vented Volume2.31 ft.³
  • Vented F326 Hz
  • BrandVisaton
  • ModelW170S - 8
  • Part Number292-568
  • UPC4007540090252
  • Product CategoryWoofers
    (2 Reviews)
  • Weight2.3 lbs.
View similar products to the Visaton W170S-8 6.5" Woofer with Treated Paper Cone 8 Ohm
