Visaton W130S-4 5" Woofer with Treated Paper Cone 4 Ohm
Brand:|Model: W130S - 4|Part # 292-562
The 9022 W130S 5" woofer from Visaton delivers amazing bass, Xmax, and midrange performance not normally found in drivers at its price point. The 4-ohm impedance is perfect for series pair use in MTM and center-channel speakers.
$33.44
Buy 4+$30.40
Part # 292-562
  • Relatively flat frequency response from 80 to 4,000 Hz
  • Able to play below 40 Hz in a proper vented cabinet
  • Great power handling and Xmax
  • 4-ohm impedance is perfect for series pair use in MTM and center-channel speakers
Visaton's 9022 W130S 5" woofer features a coated paper cone and durable rubber surround. A very balanced frequency response allows the W130S to be used as a woofer in small two-way speakers or a midbass/midrange in three-way speakers, with a crossover point as high as 4,000 Hz. This allows you to build a surround sound system with large speakers for front and left, while maintaining the same voicing in smaller surround satellite speakers. The 4-ohm impedance is perfect for series pair use in MTM and center-channel speakers.
Note: For best bass performance, install the W130S into one of the following cabinets:
• A 0.25 cubic foot sealed cabinet (F3 is 86 Hz with a Qtc of 0.75).
• A 0.71 cubic foot cabinet tuned to 44 Hz with a 1-1/4" diameter port that is 1-9/16" long.
• A 1.06 cubic foot cabinet tuned to 39 Hz with a 2-3/8" diameter port that is 4-3/4" long.
  • Nominal Diameter5"
  • Power Handling (RMS)50 Watts
  • Power Handling (max)80 Watts
  • Impedance4 ohms
  • Frequency Response50 to 12,000 Hz
  • Sensitivity86 dB 1W/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)50 Hz
  • DC Resistance (Re)3.5 ohms
  • Voice Coil Inductance (Le)0.6 mH
  • Mechanical Q (Qms)2.54
  • Electromagnetic Q (Qes)0.55
  • Total Q (Qts)0.45
  • Compliance Equivalent Volume (Vas)0.49 ft.³
  • Maximum Linear Excursion (Xmax)2.25 mm
  • Cone MaterialTreated Paper
  • Surround MaterialRubber
  • Overall Outside Diameter5.75"
  • Baffle Cutout Diameter4.21"
  • Depth2.09"
  • Sealed Volume0.22 ft.³
  • Sealed F388 Hz
  • Vented Volume0.59 ft.³
  • Vented F344 Hz
  • BrandVisaton
  • ModelW130S - 4
  • Part Number292-562
  • UPC4007540090221
  • Product CategoryWoofers
  • Weight1.499 lbs.
View similar products to the Visaton W130S-4 5" Woofer with Treated Paper Cone 4 Ohm
