Visaton W100S-8 4" Woofer with Treated Paper Cone 8 Ohm
Brand:|Model: W100S - 8|Part # 292-560
The 9021 W100S 8-ohm 4" woofer from Visaton delivers amazing bass and midrange performance not normally found in drivers at its price point.
List Price$35.22
You Save21%
Buy 4+$25.15
Part # 292-560
  • Relatively flat frequency response from 100 to 5,000 Hz
  • Able to play below 60 Hz in a proper vented cabinet
  • Great power handling and decent Xmax
Visaton's 9021 W100S 4" woofer features a coated paper cone and durable rubber surround. A very balanced frequency response allows the W100S to be used as a woofer in small two-way speakers or a midbass/midrange in three-way speakers, with a crossover point as high as 5,000 Hz. This allows you to build a surround sound system with large speakers for front and left, while maintaining the same voicing in smaller surround satellite speakers.
Note: For best bass performance, install the W130S into one of the following cabinets:
• A 0.14 cubic foot sealed cabinet (F3 is 100 Hz with a Qtc of 0.7).
• A 0.17 cubic foot cabinet tuned to 70 Hz with a 1-1/4" diameter port that is 2-3/8" long.
• A 0.35 cubic foot cabinet tuned to 56 Hz with a 1-1/4" diameter port that is 2" long.
  • Nominal Diameter4"
  • Power Handling (RMS)30 Watts
  • Power Handling (max)50 Watts
  • Impedance8 ohms
  • Frequency Response63 to 15,000 Hz
  • Sensitivity86 dB 1W/1m
  • Voice Coil Diameter0.79"
  • Resonant Frequency (Fs)63 Hz
  • DC Resistance (Re)6.7 ohms
  • Voice Coil Inductance (Le)0.5 mH
  • Mechanical Q (Qms)2.74
  • Electromagnetic Q (Qes)0.67
  • Total Q (Qts)0.54
  • Compliance Equivalent Volume (Vas)0.19 ft.³
  • Maximum Linear Excursion (Xmax)2 mm
  • Cone MaterialTreated Paper
  • Surround MaterialRubber
  • Overall Outside Diameter4.8"
  • Baffle Cutout Diameter3.7"
  • Depth1.89"
  • Sealed Volume0.152 ft.³
  • Sealed F393 Hz
  • Vented Volume0.35 ft.³
  • Vented F345 Hz
  • BrandVisaton
  • ModelW100S - 8
  • Part Number292-560
  • UPC4007540090214
  • Product CategoryWoofers
    (2 Reviews)
  • Weight1.171 lbs.
View similar products to the Visaton W100S-8 4" Woofer with Treated Paper Cone 8 Ohm
