292-614_ALT_0
292-614_ALT_1
Visaton SL87 FE-8 Ohm 3.4" Full Range Speaker 8 Ohm
Brand:|Model: SL87 FE|Part # 292-614
For building your own small high fidelity speaker, look no further than Visaton's SL87 FE. It also makes a great driver for column line arrays.
OUT OF STOCK
Due In: 10/21/2016
List Price$24.07
You Save26%
$17.91
Buy 4+$15.84
Part # 292-614
  • Rubber surround and spun plastic cone for neutral sound
  • IP64-rated for protection against dust and water
  • High power ferrite motor
Visaton designed the 3.4" SL87 FE speaker for flat frequency response from 100 to 15,000 Hz for use in small high fidelity speaker systems and for thin, column array speakers for personal professional audio use. This driver is also weather resistant for permanent installations in humid environments and for outdoor use.
A spun plastic cone is combined with a rubber surround for self-damped output without the need of a crossover, while offering IP64 protection against dust ingress and splashed water when installed in a proper enclosure. The large ferrite magnet keeps Qts down to respectable rating of 0.65 for true fidelity and a small enclosure requirement, while increasing sensitivity to 87 dB (1 watt/1 meter).
  • Nominal Diameter3-1/2"
  • Power Handling (RMS)10 Watts
  • Power Handling (max)15 Watts
  • Impedance8 ohms
  • Frequency Response75 to 18,000 Hz
  • Sensitivity87 dB 1W/1m
  • Voice Coil Diameter0.79"
  • Resonant Frequency (Fs)120 Hz
  • DC Resistance (Re)7.2 ohms
  • Mechanical Q (Qms)3.30
  • Electromagnetic Q (Qes)0.82
  • Total Q (Qts)0.65
  • Compliance Equivalent Volume (Vas)0.05 ft.³
  • BL Product (BL)3.95 Tm
  • Diaphragm Mass Inc. Airload (Mms)2.4g
  • Maximum Linear Excursion (Xmax)1.75 mm
  • Surface Area of Cone (Sd)37.3 cm²
  • Cone MaterialPoly
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter3.32" across the flats, diagonally 4.70"
  • Baffle Cutout Diameter3.15"
  • Depth1.93"
  • Bolt Circle Diameter3.86"
  • # Mounting Holes4
  • BrandVisaton
  • ModelSL87 FE
  • Part Number292-614
  • UPC4007540020914
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (3 Reviews)
  • Weight1.1000 lbs.
View similar products to the Visaton SL87 FE-8 Ohm 3.4" Full Range Speaker 8 Ohm
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
