Visaton R10S 4" Full Range Speaker 4 Ohm
Brand:|Model: R10S-4|Part # 292-595
Visaton's 2036 R10S full-range, four ohm, 4" speaker offers great frequency response and sensitivity in a compact package. Great for point-source applications with a limited amount of mounting depth space.
List Price$13.57
You Save26%
Buy 4+$9.13
Part # 292-595
  • Full range frequency response from 100 to 13,000 Hz
  • Thin mount profile with a mounting depth under 1-1/2"
  • High 90 dB sensitivity
  • 4 ohm impedance
Designed or electronic devices, and to be used in the ceiling structures of rail cars and buses, Visaton's R10S full range speaker has very linear response from 150 to 10,000 Hz. The slim design features a depth that is less than 1-1/2" for shallow mounting.
High sensitivity and good power handling combine for more output than many midrange drivers this size, while the paper cone and accordion surround create a more natural, classic sound that is pleasing to most peoples' ears. A square steel mounting plate eliminates the need for a baffle recess, while the mounting slots can accept a wider range of mounting diameters.
  • Nominal Diameter4"
  • Power Handling (RMS)20 Watts
  • Power Handling (max)30 Watts
  • Impedance4 ohms
  • Frequency Response100 to 13,000 Hz
  • Sensitivity90 dB 1W/1m
  • Voice Coil Diameter0.59"
  • Resonant Frequency (Fs)160 Hz
  • DC Resistance (Re)3.4 ohms
  • Voice Coil Inductance (Le)0.20 mH
  • Mechanical Q (Qms)5.53
  • Electromagnetic Q (Qes)1.96
  • Total Q (Qts)1.45
  • Compliance Equivalent Volume (Vas)0.07 ft.³
  • BL Product (BL)1.9 Tm
  • Diaphragm Mass Inc. Airload (Mms)1.9g
  • Maximum Linear Excursion (Xmax)0.5 mm
  • Surface Area of Cone (Sd)56 cm²
  • Cone MaterialPaper
  • Surround MaterialTreated Paper
  • Magnet MaterialFerrite
  • Overall Outside DiameterAcross the flats 4.02"
  • Baffle Cutout Diameter3.66"
  • Depth1.42"
  • Bolt Circle Diameter4.61"
  • # Mounting Holes4
  • BrandVisaton
  • ModelR10S-4
  • Part Number292-595
  • UPC4007540020365
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (2 Reviews)
  • Weight0.35 lbs.
