292-538_ALT_0
292-538_ALT_1
Visaton K50WP-8 2" Full-Range Water Resistant Speaker 8 Ohm
Brand:|Model: K50WP - 8|Part # 292-538
Choose the 8-ohm 2915 K50WP 2" full-range speaker from Visaton for outdoor applications where direct moisture, high humidity, and space limitations are a factor.
List Price$7.01
You Save16%
$5.90
Buy 4+$5.36
Part # 292-538
  • IP65 rated speaker for outdoor use
  • UL 94-rated ABS basket
  • One-piece mylar cone and surround
Visaton's 2915 K50WP 2" full-range speaker features a unique weather and UV-resistant design. A UL 94-rated ABS basket is used in conjunction with a one-piece mylar cone and surround. This allows the K50WP to be used in outdoor audio applications where water and high humidity are a factor. When used in a sealed enclosure, the front of this speaker conforms to the IP65 water resistance rating (meaning it can withstand direct moisture).
Note: For maximum power handling, a 1st-order 300 Hz high-pass filter is recommended.
  • Nominal Diameter2"
  • Power Handling (RMS)2 Watts
  • Power Handling (max)3 Watts
  • Impedance8 ohms
  • Frequency Response180 to 17,000 Hz
  • Sensitivity84 dB 1W/1m
  • Voice Coil Diameter0.39"
  • Resonant Frequency (Fs)300 Hz
  • Maximum Linear Excursion (Xmax)0.25 mm
  • Cone MaterialPoly / Mylar Diaphragm
  • Overall Outside Diameter1.97"
  • Baffle Cutout Diameter1.81"
  • Depth0.63"
  • BrandVisaton
  • ModelK50WP - 8
  • Part Number292-538
  • UPC4007540029153
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (1 Reviews)
  • Weight0.123 lbs.
View similar products to the Visaton K50WP-8 2" Full-Range Water Resistant Speaker 8 Ohm
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
