292-540_ALT_0
292-540_ALT_1
Visaton K50WP-16 2" Full-Range Water Resistant Speaker 16 Ohm
Brand:| Model: K50WP - 16
Choose the 16-ohm 2917 K50WP 2" full-range speaker from Visaton for outdoor applications where direct moisture, high humidity, and space limitations are a factor.
  • IP65 rated speaker for outdoor use
  • UL 94-rated ABS basket
  • One-piece mylar cone and surround
292-540
Weight: 0.119 lbs.
IN STOCK
List Price$5.63
You Save23%
$4.32
Part # 292-540
Visaton's 2917 K50WP 2" full-range speaker features a unique weather and UV-resistant design. A UL 94-rated ABS basket is used in conjunction with a one-piece mylar cone and surround. This allows the K50WP to be used in outdoor audio applications where water and high humidity are a factor. When used in a sealed enclosure, the front of this speaker conforms to the IP65 water resistance rating (meaning it can withstand direct moisture).
Note: For maximum power handling, a 1st-order 300 Hz high-pass filter is recommended.
  • Nominal Diameter2"
  • Power Handling (RMS)2 Watts
  • Power Handling (max)3 Watts
  • Impedance16 ohms
  • Frequency Response180 to 17,000 Hz
  • Sensitivity84 dB 1W/1m
  • Voice Coil Diameter0.39"
  • Resonant Frequency (Fs)300 Hz
  • Maximum Linear Excursion (Xmax)0.25 mm
  • Cone MaterialPoly / Mylar Diaphragm
  • Overall Outside Diameter1.97"
  • Baffle Cutout Diameter1.81"
  • Depth0.63"
  • BrandVisaton
  • ModelK50WP - 16
  • Part Number292-540
  • UPC4007540029177
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (3 Reviews)
  • Weight0.119 lbs.
View similar products to the Visaton K50WP-16 2" Full-Range Water Resistant Speaker 16 Ohm
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
Visaton K50WP-16 2" Full-Range Water Resistant Speaker 16 Ohm is rated 5.0 out of 5 by 3.
Rated 5 out of 5 by from just what I neededGreat service.. and delivrey time. product worked as advertised just what I needed
Date published: 2013-10-17
Rated 5 out of 5 by from Great products, great folks!These speakers are excellent. I used one to pepair a marine VHF radio and the specs seemed to very closely match the original.More importantly, these folks took the time to help me. They know their stuff. This isn't the first time their expert advice helped me with a "hard to fix" item.THANK YOU!!
Date published: 2013-09-30
Rated 5 out of 5 by from Nice miniature speakerI installed the K50WP-16 as a replacement in a VHF marine radio that needed a small water-resistant speaker. The factory original was badly corroded and failed. The ABS basket is slightly larger than a metal basket, but otherwise a perfect 2" replacement. Nice Mylar cone that sounds very crisp and clear for voice even at higher volume levels. Construction is better than the original and looks like it will resist moisture for many years to come.
Date published: 2013-05-20
  • 2015-03-27T07:10CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_292-540, PRD, sort_mostRecent
How can I mount these to a surface - there are no screw holes...
I'm a newbie to the DIY speakers thing, so apologies if this has already been answered somewhere I'm unaware of.
Asked by: SpeakerNewb
These are usually rear mounted with adhesive or a clamp type mount or some kind.
Date published: 2014-03-30
  • 2015-03-27T07:01CST
  • loc_en_US, sid_292-540, PRD, sort_recentQuestionsFirst
Customer projects that include: Visaton K50WP-16 2" Full-Range Water Resistant Speaker 16 Ohm
