Visaton FRS8-4 3.3" Full-Range Speaker 4 Ohm
Brand:|Model: FRS8 - 4|Part # 292-522
Choose the 2003 FRS8 3.3" full-range speaker from Visaton for sound applications where space is critical and high fidelity, full range sound is needed. 4-ohm impedance.
List Price$16.89
You Save17%
$14.08
Buy 4+$12.80
Part # 292-522
  • 4-ohm impedance for mobile and MTM center channel speaker applications
  • Rugged, compact design with rubber surround and steel frame
  • Smooth, linear frequency response from 200 to 20 kHz
Visaton's 2003 FRS8 4-ohm, 3.3" paper cone HiFi full-range driver features smooth frequency response from 200 to 20,000 Hz, making it an ideal speaker for use in surround sound satellite speakers, multimedia speakers, exhibit display speakers, even ceiling speakers!
A rugged stamped-steel frame ensures durability, as does the rubber surround. With up to 50 watts of peak power handling and wide dispersion, the 2003 FRS8 might be one of the best values in the speaker industry. The 4-ohm impedance of the 2003 FRS8 is great for series pairs used in MTM and center channel speakers, or for use in mobile and marine audio systems.
  • Nominal Diameter3"
  • Power Handling (RMS)30 Watts
  • Power Handling (max)50 Watts
  • Impedance4 ohms
  • Frequency Response100 to 20,000 Hz
  • Sensitivity82 dB 1W/1m
  • Voice Coil Diameter0.75"
  • Resonant Frequency (Fs)115 Hz
  • DC Resistance (Re)3.5 ohms
  • Voice Coil Inductance (Le)0.4 mH
  • Mechanical Q (Qms)3.61
  • Electromagnetic Q (Qes)0.85
  • Total Q (Qts)0.69
  • Compliance Equivalent Volume (Vas)0.04 ft.³
  • Maximum Linear Excursion (Xmax)0.25 mm
  • Cone MaterialPaper
  • Overall Outside Diameter3.07"
  • Baffle Cutout Diameter2.8"
  • Depth1.37"
  • Sealed Volume0.11 ft.³
  • Sealed F3133 Hz
  • Vented Volume0.12 ft.³
  • Vented F371 Hz
  • BrandVisaton
  • ModelFRS8 - 4
  • Part Number292-522
  • UPC4007540020037
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (4 Reviews)
  • Weight0.653 lbs.
