Visaton FRS5-8 2" Full-Range Speaker 8 Ohm
Brand:|Model: FRS 5-8|Part # 292-536
Designed to fit the bill for a wide range of audio applications, Visaton's 2231 FRS5 2" full-range driver features a minimalist frame and a slim design.
List Price$12.55
You Save21%
$9.89
Buy 10-49 $9.54
Buy 50+$8.87
Part # 292-536
  • Two-lug steel frame design
  • Paper cone with foam surround
  • 2" full-range speaker with linear response from 200 Hz to 20 kHz
  • Useful for background music and constant voltage PA systems
Visaton's 2231 FRS5 2" full-range HiFi driver features a minimalized two-lug frame and is suitable as a midrange driver in three-way speakers, wide-band use in background and constant-voltage industrial PA speaker systems (transformer not included). The slim design is also great for use in electronic musical instruments. A steel frame, foam surround, and paper cone are used to maximize both durability and value, making the FRS5 a great bang-for-the-buck speaker.
  • Nominal Diameter2"
  • Power Handling (RMS)5 Watts
  • Power Handling (max)8 Watts
  • Impedance8 ohms
  • Frequency Response150 to 20,000 Hz
  • Sensitivity84 dB 1W/1m
  • Voice Coil Diameter0.55"
  • Resonant Frequency (Fs)270 Hz
  • DC Resistance (Re)7.2 ohms
  • Voice Coil Inductance (Le)0.2 mH
  • Mechanical Q (Qms)3.19
  • Electromagnetic Q (Qes)1.81
  • Total Q (Qts)1.15
  • Compliance Equivalent Volume (Vas)0.00565 ft.³
  • BL Product (BL)1.6 Tm
  • Diaphragm Mass Inc. Airload (Mms)0.5g
  • Maximum Linear Excursion (Xmax)0.6 mm
  • Surface Area of Cone (Sd)12 cm²
  • Cone MaterialPaper
  • Surround MaterialFoam
  • Overall Outside Diameter2", across tabs: 2.68"
  • Baffle Cutout Diameter1.81"
  • Depth1.24"
  • Bolt Circle Diameter2.36"
  • # Mounting Holes2
  • Sealed Volume0.02 ft.³
  • Sealed F3247 Hz
  • Vented Volume0.08 ft.³
  • Vented F3150 Hz
  • BrandVisaton
  • ModelFRS 5-8
  • Part Number292-536
  • UPC4007540022314
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (3 Reviews)
  • Weight0.295 lbs.
View similar products to the Visaton FRS5-8 2" Full-Range Speaker 8 Ohm
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
