Visaton DT94-8 0.8" Polycarbonate Dome Tweeter 8 Ohm
Brand:|Model: DT94 - 8|Part # 292-556
The 9004 DT94 8-ohm, 20 mm polycarbonate dome tweeter from Visaton is designed for high power handling and features smooth frequency response.
List Price$34.54
You Save15%
$29.52
Buy 4+$26.84
Part # 292-556
  • 1.2 kHz to 22 kHz frequency response
  • Ferrofluid-cooled 8 ohm voice coil
  • 90 dB sensitivity
  • High power handling
  • Wide dispersion pattern
Visaton's 9004 DT94 8-ohm, 20 mm polycarbonate HiFi dome tweeter features smooth frequency response, high power handling (due to the ferrofluid cooled voice coil), and great dispersion characteristics that are a result of the integrated phase plug.
  • Tweeter TypePoly / Mylar Dome
  • Cone / Dome Diameter3/4"
  • Impedance8 ohms
  • Power Handling (RMS)50 Watts
  • Frequency Response1,200 to 22,000 Hz
  • Sensitivity90 dB 1W/1m
  • Resonant Frequency (Fs)1,900 Hz
  • DC Resistance (Re)63.70 ohms
  • Voice Coil Inductance (Le)0.09 mH
  • Mechanical Q (Qms)3.07
  • Electromagnetic Q (Qes)0.66
  • Total Q (Qts)0.54
  • Overall Outside Diameter3.70"
  • Cutout Diameter2.52"
  • Depth0.75"
  • BrandVisaton
  • ModelDT94 - 8
  • Part Number292-556
  • UPC4007540090047
  • Product CategoryTweeters
    (3 Reviews)
  • Weight0.615 lbs.
View similar products to the Visaton DT94-8 0.8" Polycarbonate Dome Tweeter 8 Ohm
in the Tweeters product category.
Visaton DT94-8 0.8" Polycarbonate Dome Tweeter 8 Ohm is rated 3.3333 out of 5 by 3.
Rated 2 out of 5 by from OptimusGood sound. But I had to cut an extra notch in the speaker cabinet so the wire spades would fit. It was a significant notch.
Date published: 2015-02-13
Rated 4 out of 5 by from Definitive Technology Bp-1If I am not mistaken these look exactly like the tweeters in the Def.Tech Bp-1, I just dont know if they use the 4 or 8ohm versions in the Def Tech Bp-1 speakers. If these are the same tweeters there sound is very flat and smooth. The Def.Tech.Bp-2 uses the the famous Vifa D19TD05 tweeter which sounds a littl clearer due to it being brighter sounding then the Visaton tweeter.
Date published: 2014-07-01
Rated 4 out of 5 by from Good response/excellent power handling,I'm getting another one soon. This is a replacement,and its better than the original !
Date published: 2014-03-02
  • 2016-05-05T06:22CST
  • bvseo_cps, prod_bvrr, vn_cps_3.2.0
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_292-556, PRD, sort_mostRecent
Which is the positive connection the wider connection or the thinner connection on part # 292-556
Asked by: Rick Oakes
The wider of the two is the positive terminal.
Date published: 2015-11-24
Does the cutout diameter include the attachment prongs? If not, how much width do they add? Thank you.
Asked by: Hank62
Yes, the cut out diameter does include the leads.
Answered by: MattW
Date published: 2015-07-20
  • 2016-05-05T06:46CST
  • bvseo_cps, prod_bvqa, vn_cps_3.2.0
  • loc_en_US, sid_292-556, PRD, sort_recentQuestionsFirst
