264-1028_ALT_0
264-1028_ALT_1
Vifa Tymphany BC25SC06-04 1" Textile Dome Tweeter
Brand:| Model: BC25SC06-04
Smooth-sounding compact soft dome tweeter with high output and response past 20 kHz. Neodymium motor, heatsink fins, and round faceplate.
  • Round polymer faceplate with recessed waveguide loading
  • 1" treated soft dome
  • Neodymium magnet for high output and compact size
  • Rear heatsink improves thermal management
  • Smooth frequency response extends past 20 kHz
264-1028
Weight: 0.15 lbs.
IN STOCK
List Price$22.99
You Save31%
$15.90
Buy 4-up$14.29
Part # 264-1028
Smooth-sounding compact soft dome tweeter with high output and response past 20 kHz. Neodymium motor, heatsink fins, and round faceplate. .
  • Tweeter TypeSoft Dome
  • Cone / Dome Diameter1"
  • Impedance4 ohms
  • Power Handling (RMS)50 Watts
  • Frequency Response1,350 to 30,000 Hz
  • Sensitivity96 dB 1W/1m
  • Resonant Frequency (Fs)1,350 Hz
  • DC Resistance (Re)2.9 ohms
  • Mechanical Q (Qms)2.80
  • Electromagnetic Q (Qes)2.30
  • Total Q (Qts)1.26
  • Overall Outside Diameter2.75"
  • Cutout Diameter1.70"
  • Depth1.25"
  • BrandVifa
  • ModelBC25SC06-04
  • Part Number264-1028
  • UPC844632083754
  • Product CategoryTweeters
    (48 Reviews)
  • Weight0.15 lbs.
View similar products to the Vifa Tymphany BC25SC06-04 1" Textile Dome Tweeter
in the Tweeters product category.
Vifa Tymphany BC25SC06-04 1" Textile Dome Tweeter is rated 4.8958 out of 5 by 48.
Rated 5 out of 5 by from Great SoundI bought these Vifa to produce a good clear sound for dialogue when watching movies on my HD TV and they work great, now i get clear crisp dialogue and coupled with my other speakers i now have a great system. Parts Express is a great place to buy from with the best customer service in the industry. If you have any questions or problems they will be answered and they are very professional and always follow up with problems or questions. I highly recommend Parts Express as a place to buy quality products with great customer service.
Date published: 2014-11-19
Rated 5 out of 5 by from Saved my PSB speakersI have had 5.1 surround PSB speakers for years and always thought my center channel lacked sound so I would always set my surround to 5 speaker mode essentially shutting off surround. Recently after I replaced my receiver, I realized my center channel tweeter was bad. I was able to swap the tweeter from my left speaker to the center and the sound was fixed. Replacement PSB tweeters were $50 so this seemed like the best option. I replaced all tweeters to keep the speakers matching and I could not be happier. I finally appreciate my surround after so many years. These sound great. I added the 1.8 Ohm 10W Resistor Wire Wound 5% Tolerance resistor from parts express as well so to match the impedance of the old tweeter. I wish I did it years ago!
Date published: 2014-10-22
Rated 5 out of 5 by from Great little tweeter!I just purchased these to replace the original tweeter in my PSB Image 5T tower. It was a direct fit, same dimensions as the original. Two things worth mentioning: 1st, in my opinion the tweeter was really bright. It made vocals go up an octave or two. Male vocals were definitely at a higher pitch (or tone). 2nd, the faceplate on this tweeter is flat. The PSB tweeter has a convex surface that matches the contour of the speaker. It's just a cosmetic thing I know, but the Vifa tweeter does fit the cut-out perfectly. I ended up swapping the tweeters from my 2B bookshelf speakers to the 5t's and will get another Vifa tweeter for the 2B's.
Date published: 2014-10-20
Rated 5 out of 5 by from Perfect Budget Tweeter!I bought these tweeters as an upgrade for my Yamaha NS-A636 Bookshelf Speakers and i was totally blown away at the sound these things produced! I was looking for something in a dome style to slide right into the OEM hole and these worked perfect. I also purchased the Goldwood 5.25" Midrange to go with the tweeters cause of the matching 96db. Can always count on Parts Express for great products with great prices! My bookshelf speakers will blow your hair back with no problem!
Date published: 2014-08-24
Rated 5 out of 5 by from Superior to the original tweeter it replacedI needed a replacement tweeter for a PSB Image 8c (center) and this Vifa was recommended in various forums and reviews. It fit perfectly and looked great. Based on a few forum posts, I was anticipating to pad it down but the original tweeter seemed extremely hot to my ears whereas the Vifa really tamed it down so I decided to leave it for now. What a bargain.
Date published: 2014-06-24
Rated 5 out of 5 by from Have your SQL and eat it too..Use these in a full-active system with 75 watts per channel for my mobile setup, hit the highway and just get blown away at the both the smoothness and SPL, these tweeters like to be pushed and the harder you push them the better they sound. Believe the reviews, this tweeter rocks. You can buy a more expensive tweeter but i would have to question your logic, this low dollar tweeter is worth it's weight in gold.
Date published: 2014-06-22
  • 2015-01-31T22:47CST
  • co_hasreviews, tv_0, tr_48
  • loc_en_US, sid_264-1028, PRD, sort_mostRecent
Will these fit in some infinity primus p363 speakers?
Asked by: Alumataz22
We do not have a cross reference available for this type of thing. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2015-01-19
what uf cap for 4 ohm
Asked by: jenkitt
This requires a bit more information in order to proceed. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2014-09-23
Hi there, I would like to purchase the tweeter mention below, before order I just need to confirm can this Vifa Tymphany BC25SC06-04 1" Textile Dome Tweeter Model: BC25SC06-04 fit Event 5 speakers. Thank You.
Asked by: Farid
Date published: 2014-09-19
is this tweeter available as "just the driver" without the plastic surround attached?
Asked by: Dagger
Unfortunately this is not available without the flange, although we do have a few "flangeless" tweeters available.
Date published: 2014-08-14
How far apart are the mounting screw holes?
Asked by: kgreg
The screw holes are 60mm or 2.36" apart.
Date published: 2014-06-16
What would be the volume of four units in series/parallel in DB's ??? Series and Series in parallel, yielding 8 ohms. Thank you.
Asked by: Jimpcn
You will gain a total of 6 dB output with four of these in series parallel, and it would also yield a total impedance of 4 ohms.
Date published: 2014-04-24
  • 2015-01-31T23:23CST
  • co_hasquestionsanswers, tq_18
  • loc_en_US, sid_264-1028, PRD, sort_recentQuestionsFirst
Customer projects that include: Vifa Tymphany BC25SC06-04 1" Textile Dome Tweeter
