264-1144_ALT_0
264-1144_ALT_1
Vifa TC7FD00-04 2-1/2" Full Range Paper Cone Woofer 4 Ohm
Brand:| Model: TC7FD00-04
The TC7FD00-04 2-1/2" full-range speaker was designed to be an economical yet great-performing choice for applications that include TVs, music player docking stations, and hi-fi line arrays.
  • Cost-effective ceramic ferrite magnet and stamped steel frame
  • Patented NRSC PentaCut cone technology controls resonances and improves performance
  • Under-spider venting increases power handling
  • Half-roll rubber surround for unrestricted travel
  • Copper pole piece cap controls impedance and extends HF response
264-1144
Weight: 0.4 lbs.
IN STOCK
List Price$13.99
You Save30%
$9.75
Buy 4-up$8.80
Part # 264-1144
Peerless/Vifa's TC7FD00-04 2-1/2" full-range speaker brings classic hi-fi capabilities to compact music and media systems. Tymphany's patented PentaCut paper cone technology improves musicality and accuracy, and the driver features a cost-effective ceramic ferrite magnet. A copper cap on the pole piece controls system impedance, thereby extending the upper frequency range.
The TC7FD00-04 is ideally suited for use in flat panel televisions and sound bars, MP3 and cell phone docking stations, hi-fi speaker line arrays, and multimedia PCs.
  • Nominal Diameter2-1/2"
  • Power Handling (RMS)20 Watts
  • Power Handling (max)40 Watts
  • Impedance4 ohms
  • Frequency Response130 to 20,000 Hz
  • Sensitivity82.4 dB 1W/1m
  • Voice Coil Diameter0.75"
  • Resonant Frequency (Fs)143 Hz
  • DC Resistance (Re)3.2 ohms
  • Voice Coil Inductance (Le)0.02 mH
  • Mechanical Q (Qms)3.7
  • Electromagnetic Q (Qes)1.22
  • Total Q (Qts)0.92
  • Compliance Equivalent Volume (Vas)0.02 ft.³
  • Mechanical Compliance of Suspension (Cms)0.75 mm/N
  • BL Product (BL)1.97 Tm
  • Diaphragm Mass Inc. Airload (Mms)1.64g
  • Maximum Linear Excursion (Xmax)1 mm
  • Surface Area of Cone (Sd)22.1 cm²
  • Cone MaterialPaper
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter2.95"
  • Baffle Cutout Diameter2.56"
  • Depth1.43"
  • # Mounting Holes4
  • Sealed Volume0.05 ft.³
  • Sealed F3138 Hz
  • Vented Volume0.1 ft.³
  • Vented F382 Hz
  • BrandVifa
  • ModelTC7FD00-04
  • Part Number264-1144
  • UPC844632092664
  • Product CategoryWoofers
    (3 Reviews)
  • Weight0.4 lbs.
View similar products to the Vifa TC7FD00-04 2-1/2" Full Range Paper Cone Woofer 4 Ohm
Vifa TC7FD00-04 2-1/2" Full Range Paper Cone Woofer 4 Ohm is rated 5.0 out of 5 by 3.
Rated 5 out of 5 by from Very good as a midrange driverUsed this driver in a recent two baffle surface surround speaker build for a friend. They are very clear and crisp. Very similar to Vifa's 3 1/2" 8 ohm driver TC9FD-18-08 which I use in single front baffle speakers. These are matched with Vifa's 4 ohm dome tweeter BC25SC55-04 and a slot loaded down firing GRS 6.5 poly woofer 6PR-8. I am very pleased with all Vifa products purchased to date.
Date published: 2014-12-29
Rated 5 out of 5 by from Rapport qualité/prix épatant !Montés en satellites dans un système 2.1, piloté par un miniDSP 2x4 et filtrés à 150Hz/48dB, ces petits HP font merveille. Peut-être un léger manque d'aigus mais globalement, un son très propre et une faible directivité. Si les large bande de type Fostex ne m'ont jamais convaincu, dans ce diamètre et, surtout, à ce prix le TC7 est un must.
Date published: 2014-11-23
Rated 5 out of 5 by from I have no complaintsI needed a 2.5" speaker to replace my dash speakers in my 3000GT. After trimming the square rim to a circle, they installed fine, and sound equal or better than the factory speakers. I bought some caps to make a hp filter, but they handle full bandwidth signal just fine. Don't have any complaints for a $10 speaker.
Date published: 2014-11-17
How low will it go with internal dimensions of 4"x4"x5.5" and 8x4x3 inch? Also, If with a vent wat is the suggested dimension and its f-response? Since Xmax is not too much, if u recommend vent, will PR help or have to x-over wid sub.
Asked by: arjunm009
In 4x4x5.5 assuming internal dimensions, the recommend box is sealed with an F3 of 160 Hz. In the 8x4x3 the response doesn't change much and goes up to about 170 Hz. I would not recommend going vented with these and a high pass around 150 Hz is necessary if you want a decent amount of output.
Date published: 2014-09-12
I would like to know if this speaker would fit a Harman Kardon cen -t-5. If not could someone let me know what speaker would fit. Thanks
Asked by: Mark512
Unfortunately we do not have a cross reference available for this type of thing. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2014-07-28
Is the 2.95 in from corner to corner (diagonally) or is it just he distance across the speaker.
Asked by: hijadeputanumeruno
Yes that is to the center of the mounting holes measured diagonally.
Date published: 2014-04-23
What is the mounting screw hole measurement diagonal?
Asked by: skinnyg
The screw holes are 75mm or 2.95" on center.
Date published: 2014-04-14
What enclosure is recommended for this driver?
Asked by: thunk
The recommended enclosure for this driver is sealed at roughly 0.05 cubic feet. This would be internal dimensions of 4"x4"x5.5".
Date published: 2013-06-16
Customer projects that include: Vifa TC7FD00-04 2-1/2" Full Range Paper Cone Woofer 4 Ohm
