Clearance Item
264-1140_ALT_0
264-1140_ALT_1
264-1140_ALT_2
Vifa NE265W-08 10" Subwoofer Speaker
Brand:| Model: NE265W-08
Years of experience have gone into the design and manufacture of Peerless/Vifa's NE265W-08 10" neodymium subwoofer—and it shows!
  • Cast aluminum frame promotes motor cooling
  • Sculpted design improves airflow and reduces reflections
  • High-strength compact neodymium magnet system
  • Proprietary coated natural wood fiber cone with half-roll rubber surround
  • Long-throw 2" voice coil on titanium former
  • Copper pole piece cap for extended HF response
  • 8 ohm nominal impedance
264-1140
Weight: 5 lbs.
The Peerless/Vifa NE265W-08 10" subwoofer features an open cast aluminum basket design that minimizes internal acoustic reflections and helps cool the neodymium motor. An additional heat sink provides extra thermal dissipation. The cone is constructed of a coated natural wood fiber, with a butyl rubber surround designed by finite element analysis for linearity of performance. FEA techniques also contribute to the motor's copper cap, which reduces inductance and extends the driver's upper frequency range.
  • Nominal Diameter10"
  • Power Handling (RMS)190 Watts
  • Power Handling (max)380 Watts
  • Impedance8 ohms
  • Frequency Response20 to 20,000 Hz
  • Sensitivity84 dB 1W/1m
  • Voice Coil Diameter2"
  • Resonant Frequency (Fs)23 Hz
  • DC Resistance (Re)6.2 ohms
  • Voice Coil Inductance (Le)0.53 mH
  • Mechanical Q (Qms)10.33
  • Electromagnetic Q (Qes)0.31
  • Total Q (Qts)0.3
  • Compliance Equivalent Volume (Vas)3.43 ft.³
  • Mechanical Compliance of Suspension (Cms)0.69 mm/N
  • BL Product (BL)14.7 Tm
  • Diaphragm Mass Inc. Airload (Mms)74.1g
  • Maximum Linear Excursion (Xmax)9.35 mm
  • Surface Area of Cone (Sd)326.9 cm²
  • Cone MaterialWood Fiber
  • Voice Coil FormerTitanium
  • Magnet MaterialNeodymium
  • Overall Outside Diameter10.43"
  • Baffle Cutout Diameter9.25"
  • Depth5.52"
  • # Mounting Holes5
  • Sealed Volume0.55 ft.³
  • Sealed F361 Hz
  • Vented Volume1.08 ft.³
  • Vented F338 Hz
  • BrandVifa
  • ModelNE265W-08
  • Part Number264-1140
  • UPC844632092640
    (5 Reviews)
  • Weight5 lbs.
View similar products to the Vifa NE265W-08 10" Subwoofer Speaker
Customer projects that include: Vifa NE265W-08 10" Subwoofer Speaker
