264-1132_ALT_0
264-1132_ALT_1
Vifa NE149W-08 5-1/4" Fiber Cone Woofer Speaker 8 Ohm
Brand:| Model: NE149W-08
The advanced design and superior construction of the NE149W-08 5-1/4" neodymium speaker make it a preferred component for sophisticated audio designs.
  • Cast aluminum frame promotes motor cooling
  • Sculpted design improves airflow and reduces reflections
  • High-strength compact neodymium magnet system
  • Proprietary coated natural wood fiber cone with half-roll rubber surround
  • Long-throw 1-1/2" voice coil on titanium former
  • Copper pole piece cap for extended HF response
  • 8 ohm nominal impedance
264-1132
Weight: 1.55 lbs.
IN STOCK
List Price$153.99
You Save25%
$115.21
Buy 4-up$105.40
Part # 264-1132
The Peerless Vifa NE149W-08 5-1/4" neodymium woofer is characterized by the NE Series' cast aluminum basket—an innovative sculpted, open design that minimizes internal acoustic reflections and assists the neodymium motor's thermal management.
A coated natural wood fiber cone with a butyl rubber surround is FEA optimized for linearity of performance. Finite element analysis techniques also contribute to inclusion of the motor's copper cap, which reduces inductance and extends the speaker's upper frequency performance.
  • Nominal Diameter5-1/4"
  • Power Handling (RMS)60 Watts
  • Power Handling (max)120 Watts
  • Impedance8 ohms
  • Frequency Response50 to 5,000 Hz
  • Sensitivity86 dB 1W/1m
  • Voice Coil Diameter1.5"
  • Resonant Frequency (Fs)54 Hz
  • DC Resistance (Re)6.3 ohms
  • Voice Coil Inductance (Le)0.08 mH
  • Mechanical Q (Qms)8.19
  • Electromagnetic Q (Qes)0.4
  • Total Q (Qts)0.38
  • Compliance Equivalent Volume (Vas)0.3 ft.³
  • Mechanical Compliance of Suspension (Cms)0.84 mm/N
  • BL Product (BL)7.42 Tm
  • Diaphragm Mass Inc. Airload (Mms)10.3g
  • Maximum Linear Excursion (Xmax)5 mm
  • Surface Area of Cone (Sd)85 cm²
  • Cone MaterialWood Fiber
  • Surround MaterialRubber
  • Voice Coil FormerTitanium
  • Magnet MaterialNeodymium
  • Overall Outside Diameter5.39"
  • Baffle Cutout Diameter4.92"
  • Depth3.18"
  • # Mounting Holes5
  • Sealed Volume0.09 ft.³
  • Sealed F3113 Hz
  • Vented Volume0.2 ft.³
  • Vented F363 Hz
  • BrandVifa
  • ModelNE149W-08
  • Part Number264-1132
  • UPC844632092602
  • Product CategoryWoofers
    (1 Reviews)
  • Weight1.55 lbs.
View similar products to the Vifa NE149W-08 5-1/4" Fiber Cone Woofer Speaker 8 Ohm
Vifa NE149W-08 5-1/4" Fiber Cone Woofer Speaker 8 Ohm is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Great Midrange DriverI'm renovating a pair of JBL 8330 speaker cabinets to use as reference monitors for audiovideo production. Installing this driver in the midrange provided the exact solution I was looking for to give sound more like the source and less like a 'speaker'.I've combined this with a Morel CAW938 woofer, which has an almost identical construction, and will soon add a suitable tweeter, all driven by a Bryston 4BST amp.
Date published: 2013-09-25
Customer projects that include: Vifa NE149W-08 5-1/4" Fiber Cone Woofer Speaker 8 Ohm
Discussions in our TechTalk Forum that include: Vifa NE149W-08 5-1/4" Fiber Cone Woofer Speaker 8 Ohm
