264-500_ALT_0
264-500_ALT_1
Vifa D19TD-05 3/4" Poly Dome Tweeter
Brand:| Model: D19TD-05
Affordable 3/4" poly dome tweeter features good dispersion and excellent power handling. High loss diaphragm. Voice coil is ferro fluid cooled.
  • High 80 watt RMS power handling with appropriate crossover
  • Small 3/4" dome for great off-axis response
  • Ferro fluid cooled
264-500
Weight: 0.6 lbs.
IN STOCK
List Price$29.99
You Save34%
$19.94
Buy 4-up$18.88
Part # 264-500
  • Tweeter TypePoly / Mylar Dome
  • Cone / Dome Diameter3/4"
  • Impedance8 ohms
  • Power Handling (RMS)80 Watts
  • Frequency Response3,500 to 20,000 Hz
  • Sensitivity89 dB 1W/1m
  • Resonant Frequency (Fs)1,700 Hz
  • DC Resistance (Re)6.20 ohms
  • Overall Outside Diameter3.70"
  • Cutout Diameter2.67"
  • Depth0.90"
  • BrandVifa
  • ModelD19TD-05
  • Part Number264-500
  • UPC844632020209
  • Product CategoryTweeters
    (44 Reviews)
  • Weight0.6 lbs.
View similar products to the Vifa D19TD-05 3/4" Poly Dome Tweeter
in the Tweeters product category.
Vifa D19TD-05 3/4" Poly Dome Tweeter is rated 4.9091 out of 5 by 44.
Rated 5 out of 5 by from AmazingThis tweeter went to the Netherlands, were i build more loudspeakers and this tweeter is able to project the sound very 3d into the room. Excellent !!
Date published: 2015-02-15
Rated 5 out of 5 by from Easy to install - fit my cabinets perfectly!Recently I used these Vifa tweeters & Dayton crossovers to replace those in my 1977 RTR G-200 towers; simple to install, relatively inexpensive and the speakers sound great. The replacement midrange & passive radiators were a previous purchase. So far so good.
Date published: 2015-02-03
Rated 5 out of 5 by from Works great on Infinity Reference One bookshelfMy old polycell tweeters had gone out on my infinity Reference One bookshelf speakers. I decided to take the plunge as I couldn't think of a comparable speaker that I could purchase for the price of these speakers. They worked out well.
Date published: 2015-01-28
Rated 5 out of 5 by from DAS-4 exact replacementGlad to find these as my Speakerlab DAS-4's from the early 90's were supplied with this Vifa tweeter.
Date published: 2014-11-22
Rated 5 out of 5 by from great tweeter for my refurbI'm super pleased with these. Bought 4 to in my newly acquired Polk DCM Time Windows. Would confidently recommend them to anyone looking for solid value.
Date published: 2014-11-06
Rated 5 out of 5 by from Refit Eltax sattellite speakersLooked on the internet, no one could deliver the Vifa D19TD-05.Parst expresse: no problem, received in 3 days oversea. Thanks from the Netherlands!
Date published: 2014-11-02
  • 2015-02-28T06:46CST
  • co_hasreviews, tv_0, tr_44
  • loc_en_US, sid_264-500, PRD, sort_mostRecent
I have a pair of Paradigm Titans, Version 1(early 1990's). One of the tweeters needs replacing. It is a Vifa D19TD-27 and looks identical to the Vifa D19TD-05, is it the same thing? Can't seem to find any info on the D19TD-27?
Asked by: Petra1
Would I use a non inductive or low inductive wire wound 4 ohm resistor (difference?) and would the amplifier see it as an 8 ohm load with no negative effects ?
Asked by: nikko
I want to use 2 of these in each speaker cabinet and still have an 8 ohm load to the amplifier. How do I do it? Do they come in 4 or 16 ohm versions?
Asked by: nikko
You need 4 speakers to wire them series parallel and keep the 8 ohm load. A 4 or 16 ohm version is not available. You could also add a 4 Ohm wire wound resistor in series with 2 paralleled speakers to "simulate" an 8 ohm load.
Answered by: TomI
Date published: 2015-02-02
Need replacement tweeters & crossovers for 1977 era RTR G-200 towers. Have replaced the Phillips dome tweeters multiple times and now they are shorting out. Outside diameter is 3 5/8 ", any recommendations?
Asked by: GuyMc
This requires a bit more information in order to proceed. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2015-01-20
Has anyone used these in DCM Time Window 1a speakers? What was the result?
Asked by: Noise Gate
These are a very popular replacement for Time Window speakers. I cannot however comment on the resulting sound, or possible modifications that were required for fitting.
Date published: 2014-11-24
I have a three way 12" ported speaker setup with the other speakers 8ohm. How do I bring these tweeters in line as they are 6ohm? What do I need in addition to ordering these? Thank you kindly in advance.
Asked by: Johncee
Date published: 2014-11-03
  • 2015-02-27T07:59CST
  • co_hasquestionsanswers, tq_20
  • loc_en_US, sid_264-500, PRD, sort_recentQuestionsFirst
Customer projects that include: Vifa D19TD-05 3/4" Poly Dome Tweeter
