Clearance Item
183-350_ALT_0
183-350_ALT_1
Video Projector AV Extender Wall Plate System
Video Projector AV Extender Wall Plate System allows six video signals to be sent over two runs of conventional category 5 or 6 cable, eradicating the most tedious installation problems. Termination is easy using the simple 110 punch-down terminals on each unit.
  • Six audio/video signals fit easily into a single gang electrical box
  • Accommodates: VGA, S-video, composite video, 3.5 mm stereo audio and left/right RCA audio
  • Custom length terminations using inexpensive Category 5e or Category 6 UTP cable
  • Externally powered by included switching power supplies
183-350
Weight: 1.42 lbs.
IN STOCK
List Price$299.99
Regular Price$229.00
You Save57%
Special Price
$98.00
Part # 183-350
The U.S. is in the midst of an overhaul of our educational technology. Blackboards and overhead projectors were a mainstay in the classroom for decades but this obsolete technology is being replaced by PCs, document cameras, and video projectors. In an effort to make installation cleaner and easier, integrators resort to a multitude of techniques. Field terminating cables is tedious and time consuming. Pre-terminated cables create a problem of their own when trying to push several cables into a small electrical box. Audio and video baluns are somewhat easier to use, but can degrade signal quality and cause timing errors on critical VGA signals.
The Video Projector AV Extender Wall Plate System solves the most tedious installation problems. All of the common projector signals are integrated into the transceiver pair. Two simple runs of inexpensive Cat 5e or Cat 6 cable connect the transmitter to the receiver. Termination is easy using the simple 110 punch-down terminals on each unit. VGA timing problems can be easily overcome utilizing the on-board skew compensation. The transmitter wall plate switches between audio and video inputs to capitalize on bandwidth limitations of the cables used. For example, when a composite or S-video source is turned on, the transmitter switches to the active input. When the composite or S-video device is turned off the transmitter switches back to the VGA input.
Maximum distances of 500 ft. at 1280 x 1024 resolution, 350 ft. at 1600 x 1200 resolution, and 250 ft. at 1920 x 1200 resolution. Powered by external switching power supplies (included); 5 VDC for the transmitter and 12 VDC for the receiver.
  • Audio Input/OutputL/R Analog
  • Video Input/OutputComposite,S-Video,VGA (HD15)
  • BrandParts Express
  • Part Number183-350
  • UPC848864000800
  • Product CategoryAudio / Video Distribution
  • Weight1.42 lbs.
View similar products to the Video Projector AV Extender Wall Plate System
in the Audio / Video Distribution product category.
where is the connection for the Cat 5 cable? I don't see it in the photos.
Asked by: torex
The Cat 5 connection is on the back in the form of punch down blocks, these does not have RJ45 inserts.
Date published: 2014-04-28
Is the "audio" port TS (unbalanced) or TRS (balanced)?
Asked by: x00011011
The 3.5mm port is TRS stereo.
Date published: 2014-01-24
Customer projects that include: Video Projector AV Extender Wall Plate System
