Velleman VM146 LED Lighting Effect Controller
Brand:|Model: VM146|Part # 073-224
Velleman's lighting effect generator brings control to do-it-yourself lighting projects that use LEDs or LED strip lighting. Up to 108 watts of output (36 watts/channel) are available, and each of the three channels offers 256 levels of intensity in addition to 7 different lighting effects.
  • Control three separate channels of LEDs and LED strip lighting
  • Provides up to 36W per channel, 108W total
  • Hidden controls and wire terminations
  • 256 levels of intensity per channel
  • Memory function for storing effect and custom color combination
  • Requires 10 to 15 VDC power supply (sold separately)
Velleman's VM146 lighting effect generator works with LEDs and LED strip lighting to give users custom control on do-it-yourself lighting projects. Three high power MOSFETS (one per channel) are used to handle up to 36 watts of output per channel—over 100 watts of output total.
Modes of operation available include: 256 levels of intensity per channel (create custom colors with RGB LEDs and RGB LED strip lighting), hard transition effects (running light, strobe effect, and color loop), smooth fade effects (color change, flame effect, random color, and slow loop), effect speed up/down, and memory for last effect and speed setting.
The effect choices and settings, as well as the screw-down wire terminals, are kept safe and secure inside of the small plastic housing. Red, green, and blue LEDs are built in to indicate current function. A mounting tab is included for permanent installation. Power supply required and sold separately.
Note: Please refer to the manual located in the Manual/Resources section on the right for button assignment and operation. Please observe maximum output power per channel.
• Input power (maximum): 10 to 15 VDC, 9A
• Output power (maximum): 108W (12 VDC)
• Output power per color (maximum): 36W (12 VDC)
• Control unit dimensions: 2.75" L x 3.15" W x 0.9" H
  • BrandVelleman
  • ModelVM146
  • Part Number073-224
  • UPC5410329393526
  • Product CategoryAccent & Party Lighting
  • Weight0.25 lbs.
View similar products to the Velleman VM146 LED Lighting Effect Controller
in the Accent & Party Lighting product category.
