Velleman VM114 7W Mono Audio Amp Assembled
Brand:| Model: VM114
This small amplifier is constructed around the TDA2003 IC, capable of delivering 4W RMS at 4 ohms. The IC is completely thermally and short-circuit protected. A conventional 8-18 VDC power supply is required and sold separately.
320-215
Weight: 0.5 lbs.
IN STOCK
List Price$32.48
You Save14%
$27.80
Part # 320-215
This small amplifier is constructed around the TDA2003 IC, capable of delivering 4W RMS at 4 ohms. The IC is completely thermally and short-circuit protected. A conventional 8-18 VDC power supply is required and sold seperately.
Specifications: • Power output: 7W max into 4 ohms • Total harmonic distortion: 0.05% (1W/1kHz) • Frequency response: 20-20,000 Hz (-3dB) • Signal-to-noise ratio: 86 dB (A weighted) • Input sensitivity: 40mV, 150k ohm • Overload and short-circuit protected • Required supply voltage: 15 VDC (8-18 VDC), 0.5A • Dimensions: 2.2" x 1.4".
  • Power Output (RMS Per Channel @ 8 ohms)4 Watts
  • Power (RMS/Channel 8 ohms)0 - 25 Watts
  • Special FeaturesBoard Only Module
  • Weight Range< 10 lbs.
  • BrandVelleman
  • ModelVM114
  • Part Number320-215
  • UPC5410329311605
  • Product CategoryAmplifiers
    (1 Reviews)
  • Weight0.5 lbs.
View similar products to the Velleman VM114 7W Mono Audio Amp Assembled
in the Amplifiers product category.
Velleman VM114 7W Mono Audio Amp Assembled is rated 4.0 out of 5 by 1.
Rated 4 out of 5 by from Velleman AmpI bought this amp for a home project and it works great. I would buy another.
Date published: 2012-08-28
how do you control the volume output?
Asked by: marty2
You will need some kind of attenuator or pre-amp in front of it.
Answered by: AlonzoTG
Date published: 2011-08-17
Customer projects that include: Velleman VM114 7W Mono Audio Amp Assembled
