Velleman LAB1U 3-in-1 Lab Unit
Brand:|Model: LAB1U|Part # 370-400
Velleman has taken three of the most important pieces of electronic hobbyist lab equipment and combined them into the space saving Lab 1U. With a DMM, a regulated power supply, and an adjustable temperature soldering station, 99% of your home lab needs are met.
- Order Soon - Only 3 Left In Stock
List Price$189.99
You Save21%
$149.50
Part # 370-400
  • Regulated power supply and adjustable soldering station all-in-one
  • DMM is battery powered to ensure test isolation
  • Power supply features selectable DC voltage from 3-12 VDC 2A output
Velleman has combined three of the most important pieces of electronic hobbyist lab equipment and created the space saving Lab 1U. With a DMM, a regulated power supply, and an adjustable temperature soldering station, 99% of your home lab needs are met with this unit. A 3.5" backlit LCD display on the DMM ensures readability; battery power ensures isolated measurements. Selectable DC voltage from 3-12 VDC is standard on the regulated power supply that provides up to 2A output. The 48 watt soldering station can be adjusted from 302-842°F, and is capable of lead-free soldering. Test leads for the DMM, a user manual, a sponge, a replacement soldering iron tip, and a 9V battery are all included. Specifications: Multimeter: *3.5" backlit LCD display *Automatic polarity indicator *Five DC voltage ranges from 200mV to 600V *Two AC voltage settings of 200V and 600V *Five DC current ranges from 200µA to 10A *Resistance testing from 200 ohms to 2M ohms *Diode, transistor, and continuity test functions *Data-hold function and buzzer. Regulated Power Supply: *Six selectable output DC voltages: 3, 4.5, 6, 7.5, 9, 12 *Amps out: 1.5A (2A peak) *LED overload indication *Output on/off switch *Low ripple design *LED power indication. Soldering Station: *Safe, 24V power supply *Durable ceramic 48W heating element with temperature sensor *Adjustable temperature settings: 302-842°F *Supplied with spare sponge and replacement tip.
  • BrandVelleman
  • ModelLAB1U
  • Part Number370-400
  • UPC836479007680
  • Product CategorySoldering Stations
    (3 Reviews)
  • Weight9.15 lbs.
View similar products to the Velleman LAB1U 3-in-1 Lab Unit
in the Soldering Stations product category.
Velleman LAB1U 3-in-1 Lab Unit is rated 2.6667 out of 5 by 3.
Rated 3 out of 5 by from could be betterthe 25w soldering iron with heat control will not shut off so I have to unplug the iron in between uses. with out a temperature Gage I am not sure if the controller even works right.
Date published: 2015-04-03
Rated 4 out of 5 by from Fine for this Hobbyist / ExperimenterI've owned the Lab-1 for a bit over two years, and I'm happy to have it on my workbench. I originally bought it to reduce the amount of clutter on my bench from various pieces of equipment, and it helped. Mine works well and does what it's supposed to do. The soldering iron has worked very well for me. The power cord is the same thickness as a round 120V power cable (e.g. computer pigtail), I have not had a lot of trouble with mine. And the controls and switches work reasonably well. It's consumer grade equipment, nothing more. I do have to wait for the DVM display to settle down for a couple of seconds before taking a reading, but I've seen this with other DVMs as well.Having said this, there are some significant shortcomings. Although it comes with a 120VAC power cord, the DVM is not powered from the AC mains. It has a 9-volt battery that sits in a drawer in the back of the unit. This is very disappointing, as I frequently think that I've switched it off using the main power switch when I leave. You have to turn the DVM range selector to its off position or the battery will be dead the next time you arrive. That's just silly, because the unit has its own DC power supply. How hard would it have been to power the DVM?The other problem I have is that the first one that I received from P.E. was not packaged very well. It looked like it had been dropped from a great height and was destroyed. The DVM's digital display had been knocked out of place. In P.E.'s defense, I will say that they wasted no time shipping me a replacement. They sent it as soon as I notified them.I'm still quite happy to see this unit on my workbench. It has been handy for many small repairs and experiments, and makes my work area easier to keep clean.
Date published: 2011-12-11
Rated 1 out of 5 by from Didn't win me overMany of the Velleman products are excellent but this one unfortunately isn't one of them. Just a few of many gripes include a dangerous and potentially hazardous control pot on the power supply--voltage and current all over the place with the slightest touch. The soldering station iron lead would be better suited as an automotive jumper cable, large, stiff, bulky and binds up like an air hose most of the time. Very poor temperature control. The switches and indicators are extremely poor quality -- This isn't anything close to a quality piece even for the occasional user or part-time hobbyist. I gave mine away after 3 months.
Date published: 2009-05-09
  • 2016-02-12T06:06CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_370-400, PRD, sort_mostRecent
