Velleman FLPS Cold Cathode Power Supply for 12" Lamps
Brand:| Model: FLPS
Use Velleman's small FLPS to power Velleman's 12" cold cathode lamps, converting 12 VDC to the proper 180~800 VAC working voltage.
  • Power converter for Velleman''s 12" cold cathode lamps
  • Low 4W power consumption
  • Small size is easy to hide
073-266
Weight: 0.1 lbs.
IN STOCK
List Price$9.99
You Save40%
$5.90
Buy 4-up$5.00
Part # 073-266
Velleman's FLPS is designed to convert 12 VDC to the 180~800 VAC working voltages used by the Velleman's 12" cold cathode tubes. The FLPS features a small housing that is easy to hide and a female jack for secure connection to the pre-wired connectors attached to the cold cathode tubes. For connection to a 12 VDC power source (available separately), 12" power leads are provided.
• Power requirements: 12 VDC, 500 mA
• Output voltage: 180~800 VAC
• Average power consumption: 4.5 watts
• Housing dimensions: 2.40" L x 0.83" W x 0.59" H
  • BrandVelleman
  • ModelFLPS
  • Part Number073-266
  • UPC836479002579
  • Product CategoryAccent & Party Lighting
    (1 Reviews)
  • Weight0.1 lbs.
View similar products to the Velleman FLPS Cold Cathode Power Supply for 12" Lamps
in the Accent & Party Lighting product category.
Velleman FLPS Cold Cathode Power Supply for 12" Lamps is rated 4.0 out of 5 by 1.
Rated 4 out of 5 by from Great little driver for ccfl tubes even up to 2ft.Only problem is the connector only comes with the tube purchase. If you want this supply for tubes you already have, you need a mating connector with pigtails for the little white 2-pin HV header. It should really come with this since it's almost (or is) impossible to solder directly to these pins without melting the little white housing. So you have to make your own female connector for each pin and it becomes flimsy at best. Really needs to come with its own mating connector and pigtails. I have 6 of these with no good way to connect the HV side.
Date published: 2013-10-31
Is there a power supply available that will power multiple tubes?
Asked by: MagePro
Any 12v power supply with the proper current draw will work. Without a specific number of devices its hard to provide a part number. These draw .5 amps each, simply add up the number you would like to use and find a suitable power supply that will handle the current draw.
Date published: 2012-11-07
One Lamp = One Power Supply?
Or multiple lamps on 1 power supply?
Asked by: mexbungalows
Each lamp requires its own power supply, they are not designed to run in multiples from one power supply.
Answered by: RussR
Date published: 2012-04-19
Do I need 1 power supply for every 12" lamp or can 1 power supply do multiple lamps?
Asked by: FINATIC
Answered by: RussR
Customer projects that include: Velleman FLPS Cold Cathode Power Supply for 12" Lamps
