073-258_ALT_0
073-258_ALT_1
Velleman FLG Cold Cathode Lamp Green 12"
Brand:|Model: FLG|Part # 073-258
Velleman's green 12" cold cathode lamps offer a quick and convenient way to add custom lighting to nearly anything: cars, cabinets, computer cases... the only limit is your imagination. Requires the Velleman FLPS power converter and a 12 VDC power supply (sold separately).
Comparable Items In Stock:
Part # 073-258
  • Perfect size for adding light to cabinets, PCs, and counters
  • High output that's visible even in bright conditions
Easily add exciting, low-heat lighting to PC cases, cabinets, cars…virtually anywhere with a 12" cold cathode lamp from Velleman! The small size makes it easy tuck away in hard to reach spaces. Each lamp is pre-attached with a 9" long wiring harness for quick connection to the Velleman FLPS power converter and a 12 VDC power supply (sold separately). Please see Related Items for recommended power supply and power converter.
Note: Not recommended or rated for outdoor use.
• CCFL dimensions: 1/8" dia. x 12" L
• Tube voltage: 180 to 800 VAC
• Brightness: 15,000 cd/m²
• Average lifetime: 15,000 hours (almost two years of continuous use)
  • BrandVelleman
  • ModelFLG
  • Part Number073-258
  • UPC836479002531
  • Product CategoryCold Cathode Accent Lighting
  • Weight0.05 lbs.
View similar products to the Velleman FLG Cold Cathode Lamp Green 12"
in the Cold Cathode Accent Lighting product category.
