073-256_ALT_0
073-256_ALT_1
Velleman FLBL Cold Cathode Lamp Blacklight 12"
Brand:|Model: FLBL|Part # 073-256
Velleman's 12" cold cathode blacklight lamps offer a quick and convenient way to add custom lighting to nearly anything: cars, cabinets, computer cases... the only limit is your imagination. Requires the Velleman FLPS power converter and a 12 VDC power supply (sold separately).
  • Perfect for adding custom blacklight effects to cabinets, PCs, and counters
  • High output that's visible even in bright conditions
Easily add exciting, low-heat blacklight effects to PC cases, cabinets, cars…virtually anywhere with a 12" cold cathode blacklight lamp from Velleman! The small size makes it easy tuck away in hard to reach spaces. Each lamp is pre-attached with an 9" long wiring harness for quick connection to the Velleman FLPS power converter and a 12 VDC power supply (sold separately). Please see Related Items for recommended power supply and power converter.
Note: Not recommended or rated for outdoor use.
• CCFL dimensions: 1/8" dia. x 12" L
• Light wavelength: 365 nm
• Tube voltage: 180 to 800 VAC
• Brightness: 15,000 cd/m²
• Average lifetime: 15,000 hours (almost two years of continuous use)
  • BrandVelleman
  • ModelFLBL
  • Part Number073-256
  • UPC836479002524
  • Product CategoryAccent & Party Lighting
  • Weight0.05 lbs.
