Velleman CHLSC1 High Power RGB LED Control Unit w/IR Remote
Brand:|Model: CHLSC1|Part # 073-220
Velleman's high power RGB LED control unit, with IR controller, offers nearly unlimited potential for the use of RGB LED strip lighting (or up to 3 different single-color LED strips). You can also sync multiple control units together for increased area coverage. Includes 24-key IR remote control.
OUT OF STOCK
Awaiting Updated Due Date
List Price$79.99
You Save25%
$59.98
Part # 073-220
  • Control up to 49 feet of LED strip lighting (RGB or 3 different colors)
  • Link multiple controllers together—up to 164 feet apart!
  • Includes 24-key IR remote control
  • Adhesive backed and includes screws for permanent mounting
  • Requires power supply
Velleman's CHLSC1 high power RGB LED control unit allows you to power and control up to 49 feet (15 meters) of RGB LED strips on a single run. Additionally, multiple controllers can be daisy-chained and synced together using the built-in data bus, for single control over multiple LED strips. The maximum length of the data bus is 164 feet (50 meters), and provides an amazing amount of area coverage. Each controller requires its own power supply.
A 24-key infrared remote control is included for quickly powering LED strips on or off, changing through one of 16 different colors, controlling brightness, or for using one of the four built in color loop modes: flash (a 7-color flashing loop), strobe (3-color strobe loop), fade (7-color quick fade), or smooth (7-color smooth fade).
The Velleman CHLSC1 features and function control button for local function changes, and is designed to work with both 12 VDC and 24 VDC LED strips (do not mix strip voltages), and can alternatively power up to three different single-color strips on a single controller. Adhesive has been pre-mounted on the back of the controller for permanent placement, and two mounting screws are included. IR remote control uses a single CR2025 battery (battery included), see Related Items for replacements.
Note: Only use the correct power supply for the stated LED strip voltage. Please refer to the LED strip packaging or manufacturer prior to connecting power supply to controller. Never link the outputs of multiple controllers.
• Input power (maximum): 12 VDC, 15A or 24 VDC, 15A
• Output power (maximum): 180W (12 VDC), 360W (24 VDC)
• Output power per color (maximum): 60W (12 VDC), 120W (24 VDC)
• Control unit dimensions: 4.76" L x 2" W x 1.02" H
• IR remote control range: 23 ft. (7 meters)
  • BrandVelleman
  • ModelCHLSC1
  • Part Number073-220
  • UPC5410329423018
  • Product CategoryAccent & Party Lighting
  • Weight0.45 lbs.
View similar products to the Velleman CHLSC1 High Power RGB LED Control Unit w/IR Remote
in the Accent & Party Lighting product category.
I Have 5 - 7' RGB LED strips on a back bar that is on 12+ hours a day. What controller and power supply do you recommend?? Thanks in advance
Asked by: LEDDoug
Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531
Answered by: MattW
Date published: 2015-07-24
I have about 54' of a soffit I want to cover with 300LED RGB strips for uplighting.  Would I need 2 of these controllers & which power supplies should I use?
Asked by: ClemsonJeeper
Yes you will need two controllers. I would recommend part number 320-3148 as a power supply.
Date published: 2014-07-02
does this unit have an external input for the IR.
Asked by: larrys
Unfortunately no.
Date published: 2014-06-30
Is it possible to control the colors and brightness via the Data + and Data-? If so what type of network is it?
Asked by: Dan N
No. The Data terminals are only used to connect two or more control units together.
Answered by: CurtisT
Date published: 2013-01-23
Which power supply should I purchase if I want to link 4 strips of the RBG LED lighting to this controller. What part number do you recommend?
Asked by: JohnA
First, this controller is not rated to drive four of the 5m LED strips. It is rated to drive up to 49 feet, which is right about 15m, or three (3) full-length LED strips. Attempting to drive four 5m strips would be likely to damage the controller and/or the LED strips, and would void any warranties involved. That being said, I'd suggest the power supply linked below to drive the maximum of three LED strips to full output.
Answered by: RussR
Date published: 2012-10-26
  • 2016-02-09T07:26CST
  • co_hasquestionsanswers, tq_5
  • loc_en_US, sid_073-220, PRD, sort_recentQuestionsFirst
