UV 5mm LED 200 mcd 100 Piece Kit with Voltage Dropping Resistors
Brand:|Model: DC-LE13115|Part # 073-016
This package includes 100 ultra-violet LEDs together with 200 voltage dropping resistors for use with either 5 VDC or 12 VDC source voltages.
List Price$9.99
You Save18%
$8.23
Buy 4+$7.40
Part # 073-016
  • Design your own blacklight
  • Includes 200 voltage dropping resistors (100 for 5 VDC, 100 for 12 VDC)
  • Waterproof and shatterproof
Design your own lightshow with with UV LEDs. Ideal for use with fog machines, custom interior illumination, or as signal indicators; this LED kit includes voltage dropping resistors for use with 5 or 12 VDC source voltages. Extreme heat and vibration won't deter these LEDs, and their waterproof and shatterproof design allows them to be used just about anywhere.
Specifications: • Size: 5 mm • Lens color: Water clear • Forward current: 60 mA continuous, 120 mA peak • Peak wavelength: 400 nm • Forward voltage: 3.2 to 3.4 VDC • Viewing angle: 25° • Luminous intensity: 120 to 200 mcd.
  • Size5mm (T-1 3/4)
  • Emitting ColorUltraviolet
  • Lens Type / ColorWater Clear
  • Luminous Intensity200 mcd
  • Application TypeSteady
  • BrandSure Electronics
  • ModelDC-LE13115
  • Part Number073-016
  • UPC844632093425
  • Product CategoryLEDs
  • Weight0.1 lbs.
View similar products to the UV 5mm LED 200 mcd 100 Piece Kit with Voltage Dropping Resistors
in the LEDs product category.
How many nm are the leds?
I understand that the lower the nm the better, so i wanted to know, how many nm is it?
Asked by: spiderman
These have a wavelength of 400 nM
Answered by: Chrisf
Date published: 2013-01-08
What resistor to use for 120ac
Asked by: cowboy4884
for a single device? These are LEDs. they can only be used with DC power supplies. Conceivably you could have one chain going one way and a second chain going the other way but that would yield an unplesant strobing effect. So you need a bridge rectifier. (I wish parts Express carried the DB104 or similar). -- you can build the same circuit with loose diodes. You would then use a 100uF/250v capacitor, and obtain 150VDC. So you would make a chain of 42 LEDs, which leaves (very approximately; many variables) 10 volts of DC to drop, which is fairly reasonable. You need to pass .06 ampres so the resistance is somewhere around 166 ohms... Nearest standard value is 180 ohms. If you don't want 42 LEDs in series, then you're going to need some kind of transformer or a normal DC power supply.
Answered by: AlonzoTG
Date published: 2012-06-24
  • 2016-02-10T07:57CST
  • loc_en_US, sid_073-016, PRD, sort_recentQuestionsFirst
