360-510_ALT_0
360-510_ALT_1
360-510_ALT_2
USB Microscope 1.3 MP 20-200x Magnification with LED Lamp
Brand:|Model: DC-TE11122|Part # 360-510
This USB 1.3 mega-pixel microscope is perfect for close-up inspection on the go, at home, or in the lab. Get a better perspective on jewelry, currency, circuit boards, and insects, with 20x to 200x magnification and eight LED lamps. Records both stills and video for quality assurance purposes.
List Price$69.99
You Save36%
$44.98
Buy 4+$42.23
Part # 360-510
  • Perfect for professional and personal use
  • 20x to 200x magnification with 8 LED illumination
  • Takes still images and records video
  • 1.3 mega-pixel CMOS sensor with up to 1600 x 1200 resolution
  • Software, manual, and removable stand included
USB microscopes are a very useful tool for use in science and engineering applications, detailed repair, assembly and quality control, hobbies, law enforcement, or for teaching!
This 1.3 mega-pixel USB microscope is designed for use with PCs and supports still image capture (via the snapshot button) as well as video recording for micro-measurement work. The adjustable 20x to 200x magnification allows you to dial in the image, and eight built-in LED lamps offer a bright, clear picture.
Included with the microscope is a CD with manual and software, and a removable and adjustable stand.
• Camera: 1.3 mega-pixel CMOS sensor
• Image resolution: 160 x 120, 320 x 240, 640 x 480, 1280 x 1024, 1600 x 1200
• Image format: JPEG, BMP
• Video resolution: 160 x 120, 320 x 240, 640 x 480, 1280 x 1024
• Video format: AVI
• Magnification: Adjustable from 20x to 200x
• Focal range: 10 mm to 500 mm
• PC interface: High-speed USB 2.0
• Compatible with Windows XP/Vista/7
  • BrandSure Electronics
  • ModelDC-TE11122
  • Part Number360-510
  • UPC844632098345
  • Product CategoryBench Lamps & Magnifiers
    (8 Reviews)
  • Weight0.65 lbs.
View similar products to the USB Microscope 1.3 MP 20-200x Magnification with LED Lamp
in the Bench Lamps & Magnifiers product category.
USB Microscope 1.3 MP 20-200x Magnification with LED Lamp is rated 3.875 out of 5 by 8.
Rated 5 out of 5 by from Great Value for the $$$I bought this for diamond phono stylus inspection. OK, but has its limits for that. Also used for printed circuit inspection. I've used it more often for skin inspection (cancer) and you can make a good photo image to take to the doc. Stamps, bills, coins, jewelry, proof marks etc. all work well. Avoid looking into the very bright led--a strong caution for children! Hard to imagine a 200x alternative at this price point.
Date published: 2015-01-19
Rated 2 out of 5 by from OKfor the priceMade of plastic, it doesn't show a great look but it could be worse.Optically, it's a 5 out of 10. For hobby or fun purpose it's fine.
Date published: 2014-01-29
Rated 4 out of 5 by from handy but top-heavyThis such a handy tool! It gives good images and is quite easy to use. The driver has a crummy interface and I wish I could find a alternative. It would be wonderful to have an interface for tablets. The base is lightweight and the camera falls over too easily so I stuffed some pennies inside the base. It is much more stable.
Date published: 2014-01-17
Rated 2 out of 5 by from Interesting toyBought this to do inspections of the diamond stylus on my phono cartridge. The mount point between the body of the scope and the bracket (a pin and socket arrangement) is loose on the unit I got which makes it difficult to use because it is not stable. It works well otherwise. The LED lighting washes out contrast (too bright). But for the price, it's an interesting toy.
Date published: 2013-09-23
Rated 4 out of 5 by from Good ItemI'm impressed with the overall quality and value. The software works well and it's easy to get a nice, bright, clear image. Magnification is about right. As others have stated, the base could be more stable. I solved that by using duct seal ( which is a modeling clay like material used for electrical conduits) and lead fishing weights. I removed the pad from the bottom of the base and filled it with as much lead and duct seal as I could and replaced the pad. Much better. You could also use other heavy items and material to hold them in place. The duct seal is nice since it remains pliable and is sticky.
Date published: 2013-01-10
Rated 5 out of 5 by from GREAT item idea!While I like the product, features and ease of use, it tends to be limited due to the stand being on the lightweight side. It would be more useful in the higher magnification ranges if the ability to hold it steady and in focus were addressed. The nicest thing about it is that seeing the objects bring viewed on a large screen cuts neck strain and eye strain to a minimum. After using microscopes on stands for many years... it's REALLY the best feature!!
Date published: 2012-12-21
  • 2016-02-10T06:32CST
  • co_hasreviews, tv_0, tr_8
  • loc_en_US, sid_360-510, PRD, sort_mostRecent
So..I can't use this with my MacBook Pro ?
Asked by: Cdxjo
Unfortunately no.
Date published: 2014-06-16
Will this be ready for Windows 8?
Asked by: Johannes
Yes this will work with Windows 8.
Date published: 2013-08-22
  • 2016-02-10T07:17CST
  • loc_en_US, sid_360-510, PRD, sort_recentQuestionsFirst
