Ultimate Support TS-100B Air-Powered Lift-Assist Tripod Speaker Stand
Brand:|Model: TS-100B|Part # 242-700
Air-Powered Series speaker stands from Ultimate Support represent everything all other speaker stands aspire to be. The TS-100 is incredibly strong, extraordinarily sturdy, lightweight, 100% field serviceable, AND raises and lowers speaker stands on its own!
Special BOGO Offer -- Click here to get two for the price of one -- Exp 12/31/16
List Price$219.99
You Save32%
Part # 242-700
  • Internal shock raises speakers on its own – raise and lower the speaker with ease
  • Over-sized heavy wall aluminum wall tubing – incredibly strong yet surprisingly lightweight
  • Patented tripod design
  • Die-cast metal collar that prevents over tightening and breakage issues
  • Truly portable – quickly folds into a compact, lightweight unit
  • 100% field serviceable parts
  • Limited lifetime warranty
Ultimate Sound TS-100's internal shock holds the speaker weight under a neutral load, reducing the lift load by 75% on average. Simply turn the telescoping knob and the TS-100 assists in smoothly raising and lowering heavy loads with minimal effort. Larger diameter, anodized tubing and metal reinforced clamps securely support more weight than other stands. Stand quickly folds into a compact, lightweight unit. Integrated sizing adapter and rubber foot caps that won't fall off. Limited lifetime warranty.
Specifications: • Height: 3' 8" to 6' 7" (1118-2007 mm) • Folded dimensions: 43.5" x 5.5" (1105 x 140 mm) • Base diameter: 47" (1194 mm) • Telescoping tube diameter: 1-1/2" (38 mm) • Adapter diameter: 1-3/8" (35 mm) • Load capacity: 150 lbs. (68.2 kg).
Raise and Lower the Speaker with Ease!
The TS-100 is the easiest speaker stand to use thanks to the internal air-powered shock that literally raises the speaker for you. The stand's internal shock easily raises speakers weighing 50 lbs. and less with no effort from the user (the Mackie SRM Series, JBL EON Series, and QSC K Series all weigh far less than 50 lbs., for instance). And, the TS-100 requires very little effort from the end user to raise speakers weighing more than 50 lbs. When you're ready to lower the speaker, we've provided a convenient and ergonomic hand grip from which you can lower the speaker - with just one hand. There's never been an easier, more convenient, or safer way to set up and tear down speakers.
Patented Tripod Design
The TS-100's offset tripod base design provides more support than typical "off-the-shelf" speaker stands. The design makes for very tight internal fittings, doing away with unnecessary sloppy leg problems, and includes a super strong die-cast metal collar that prevents over-tightening and breakage issues associated with all plastic designs.
Over-sized Heavy Wall Aluminum Tubing
The entire stand (legs, mast, and telescoping tube) uses over-sized, heavy-walled aluminum tubing for durability, functionality, and weight savings. The TS-100 will not rust or corrode (thanks to its architectural anodized finish), is very smooth to operate, and is extraordinarily strong yet lightweight.
100% Field Serviceable Parts
From the foot caps on the bottom of the tripod legs all the way up to the speaker adapter at the top of the stand, the TS-100 is serviceable by parts as needed over its very long lifespan. In the unlikely event that something does break on the TS-100, simply replace with an affordable part instead of throwing the entire stand away and buying a whole new one!
  • BrandUltimate Support
  • ModelTS-100B
  • Part Number242-700
  • UPC784887167598
  • Product CategoryTripod Speaker Stands
    (2 Reviews)
  • Weight13.3 lbs.
View similar products to the Ultimate Support TS-100B Air-Powered Lift-Assist Tripod Speaker Stand
in the Tripod Speaker Stands product category.
