Tymphany XT25TG30-04 1" Dual Ring Radiator Tweeter
Brand:|Model: XT25TG30-04|Part # 264-1016
The XT25TG30-04 from Tymphany (formerly Vifa) features a patented dual concentric diaphragm and a unique wave guide center plug which provide an excellent on- and off-axis response.
List Price$44.99
Regular Price$32.90
You Save15%
Sale Price
$28.00
Part # 264-1016
  • Outstanding performance in 2-way systems
  • Dual ring radiator diaphragm (patented)
  • Waveguide center plug (patented)
  • Copper-clad aluminum VC wire
  • Flat response well beyond 20 kHz
  • Low distortion
This superb transducer features a patented dual concentric diaphragm and a unique wave guide center plug which provide an excellent on- and off-axis response. The XT25-type tweeter is acclaimed for its very natural sound with an extremely smooth frequency response that extends well beyond the human hearing range. The dual chamber design and absence of ferrofluid results in a low resonance frequency.
  • Tweeter TypeSoft Dome
  • Cone / Dome Diameter1"
  • Impedance4 ohms
  • Power Handling (RMS)110 Watts
  • Frequency Response1,300 to 20,000 Hz
  • Sensitivity91 dB 1W/1m
  • Resonant Frequency (Fs)436 Hz
  • DC Resistance (Re)3 ohms
  • Voice Coil Inductance (Le)0.01 mH
  • Mechanical Q (Qms)2.5
  • Electromagnetic Q (Qes)0.54
  • Total Q (Qts)0.44
  • Overall Outside Diameter4.09"
  • Cutout Diameter2.83"
  • Depth1.77"
  • BrandTymphany
  • ModelXT25TG30-04
  • Part Number264-1016
  • UPC844632083693
  • Product CategoryTweeters
    (16 Reviews)
  • Weight1.2 lbs.
View similar products to the Tymphany XT25TG30-04 1" Dual Ring Radiator Tweeter
in the Tweeters product category.
Tymphany XT25TG30-04 1" Dual Ring Radiator Tweeter is rated 4.6875 out of 5 by 16.
Rated 5 out of 5 by from Excellent twitterExcellent twitter! It works very accurately. Bottom operate Dayton RS180P-8. As always, all-wheel drive, active crossover 4th order, 2300Hz.
Date published: 2016-01-22
Rated 4 out of 5 by from Great TweetersAfter getting my Paradigm Studio 100 V2 back from a friend, I found out he had fried my tweeters. Paradigm wanted around $500 to replace them. I purchased these and swapped the covers to fit mine, and they sound like new!Thank you Parts Express!
Date published: 2015-05-04
Rated 5 out of 5 by from Great at any price, in the right applicationFirst, I'll say you need to use the right kind of tweeter in the right place. This is not the tweeter to use in a car door... but in front of your face these are smooth and open.Many can't hear above 20k (my brother can't), but if you can (as I can) a tweeter that drops off above 20k sounds like you have cotton in your ears. I used to run expensive MB Quart titanium domes specifically because they had the high frequency headroom, but once I put these in a center channel speaker, my eyes were opened. I couldn't listen to the titanium domes anymore because these ring-radiators sounded as open without the titanium harshness... so smooth! I swapped out all my $200+ MB Quarts for these $30 Vifas (and put the smaller neodymium versions in my car), and never looked back.Tips:As some have said, ignore the low frequency response rating. This is a universal rule with tweeters because the impedance always peaks at the resonant frequency - you want to cross them out well above this area. If you're a two-way snob, get a woofer that can respond above 2,400, because that's the lowest you can safely run these (I blew one x-ed at 1,850, 24db active)... if your crossover is 6db or 12db go higher. Besides, why would you want to muddy their wonderful highs by trying to push low frequencies? Three-way is a piece of cake.Also as some have said, they're directional, so they belong in a front sound stage - center or front mains... but I wouldn't call that a negative, it's just something to keep in mind for your application.In a car they work best reflecting off your windshield because of the off-axis sensitivity. In a door pillar you would only hear the one closest to you, in a side door only the one far from you... don't use these in those locations! The 1" neodymium version is much smaller, cheaper and can fit just about anywhere. It supposedly has an even lower frequency response, but don't try it.
Date published: 2014-04-24
Rated 5 out of 5 by from Exact replacement for Blue Sky Sat 6.5Blue Sky said to get it from Parts Express, because it was less than they could sell it for. Arrived on time.
Date published: 2014-03-31
Rated 5 out of 5 by from One of the best tweeter you can buy for under $200Hello, I've been an audiophile for 25 years and have heard sold and heard all kinds of speakers. I can say that I think this tweeter is one if the most natural, open and resolving tweeters I've heard. I've put them in two pairs of speakers I own / built and I would never even consider using anything else for under the $200 price range. They really are amazing. The speaker pictured is with the Dayton 6" reference woofer crossed over at 3K (12db per octive) and they fill my 18 X 15 room with pinpoint imaging and SPL with no sence of strain from my 125 wpc amplifier.
Date published: 2013-10-10
Rated 5 out of 5 by from Exact replacementThese tweeters were an exact replacement for myBlue Sky SAT 6.5 speakers, shipped quick, work great.For anyone replacing older Vifa's with the newer model, be aware that they changed the position of the terminals slightly,and some cabinets will require using a round wood file/raspand cutting 2 notches to clear the new terminals. Other than that, a perfect replacement.
Date published: 2013-08-20
  • 2016-02-12T06:24CST
  • co_hasreviews, tv_0, tr_16
  • loc_en_US, sid_264-1016, PRD, sort_mostRecent
Can I install these in my Polk TSI 500 speakers. According to Polk the crossover is at 2500kHz for all TSI series.
Asked by: Djkail
We do not have a cross reference available for this type of thing. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2015-12-11
can the flange be removed from these, and can they be underhung?
Asked by: jackie2277
Unfortunately these face plates are no removable.
Date published: 2015-09-29
Can i replace factory tweeter with these on a Polk Audio TSI500 floor standing speakers?
Asked by: dannyrey78
Date published: 2015-02-11
whats the difference between "Vifa XT25TG30-04 1" Dual Ring Radiator Tweeter" and "Vifa XT25SC-30" ???
Asked by: Sounddude
The SC has a Neodymium Magnet and a smaller surround
Answered by: obrsbr6
Date published: 2015-01-29
I bought these tweeters, I hook them up to my exiting crossover. The sound like a cover's is over them. I like to by pass my crossover. I would like try few capacitors to see it would sound like. The speakers have woofers 1 mid 1 tweeter.
Asked by: bunnyman
Please email or call our tech support for help with this. 800-338-0531 or tech@parts-express.com.
Date published: 2014-06-19
is the xt25tg30 as difficult to use as many say it is? such as zaphaudio, needing highish xover and steep slope and LCR network.... on and on?
Asked by: drum
Not that we are aware of. I would look for specifics on why it would be necessary, certainly something beyond subjective listening.
Answered by: Eric Chandler
Date published: 2014-06-03
  • 2016-02-12T07:07CST
  • co_hasquestionsanswers, tq_15
  • loc_en_US, sid_264-1016, PRD, sort_recentQuestionsFirst
